Everything you always wanted to know about Japan...
no plans yet, I was just gonna wing it when I got there... (or follow the crowd I guess). My gf has a relo in Osaka so I was gonna use that as my base of operations...
I think this Japan forum should be renamed Rezz's Forum - as he has posted up nearly all the threads:D
I do have a question though, on one of the other threads it says baka = stupid, I was under the impression that this actually means crazy or does it mean both.
Also, could you enlighten me to about gaijin - I have been told by a ex pat Jap that it is a derogatory term, to quote 'same as calling a negro a African American' is this true also?
gaijin means outsider... foreigner... unwelcome invader (according to old scripts)... so yeah it meas "you're not welcome amongst us, bugger off" in polite terms. Thing with most ordinary japs is they won't curse at you if they're pissed, but they won't make u feel very welcome either.
Rezz`s Forum? Nooooooooo, please please post up more threads people!:)
Baka: Stupid, silly, foolish.
Kurutteiru: crazy. (this is very direct in meaning)
About what you said about 'same as calling a negro a African American', that aaaaaalmost sums it up in todays language. For example, two foreigners will use Gaijin in passing conversation such as: "Hey mate, did you go to that new Gaijin bar in Shinsaibashi?", but on the other hand, if a foreigner approaches a Japanese girl and it's obvious he's just out for a screw, she maight say "Leave me alone, Gaijin!"... where the emphasis is on "Gaijin", being so that the word is used in a derogitory way to cause ill feeling, kind of like "African American"...
My 2c... what do you say Demon Dave?
Rezz, right on the money there.
That pretty much sums up the word gaijin as far as I understand it. By the way, if you want to use a more "polite" term, use Gaikokujin... :)
Generally though, most foreigners refer to each other as Gaijin's anyway! :)
just wonder how the drag strips in japan are?
I notice they dont spray much traction compound(im not sure just by watching videos),and the strip itself looks like a normal road. This must be good for street radial tires but bad for full slick drag cars?
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
