Everything you always wanted to know about Japan...
no plans yet, I was just gonna wing it when I got there... (or follow the crowd I guess). My gf has a relo in Osaka so I was gonna use that as my base of operations...
I think this Japan forum should be renamed Rezz's Forum - as he has posted up nearly all the threads:D
I do have a question though, on one of the other threads it says baka = stupid, I was under the impression that this actually means crazy or does it mean both.
Also, could you enlighten me to about gaijin - I have been told by a ex pat Jap that it is a derogatory term, to quote 'same as calling a negro a African American' is this true also?
gaijin means outsider... foreigner... unwelcome invader (according to old scripts)... so yeah it meas "you're not welcome amongst us, bugger off" in polite terms. Thing with most ordinary japs is they won't curse at you if they're pissed, but they won't make u feel very welcome either.
Rezz`s Forum? Nooooooooo, please please post up more threads people!:)
Baka: Stupid, silly, foolish.
Kurutteiru: crazy. (this is very direct in meaning)
About what you said about 'same as calling a negro a African American', that aaaaaalmost sums it up in todays language. For example, two foreigners will use Gaijin in passing conversation such as: "Hey mate, did you go to that new Gaijin bar in Shinsaibashi?", but on the other hand, if a foreigner approaches a Japanese girl and it's obvious he's just out for a screw, she maight say "Leave me alone, Gaijin!"... where the emphasis is on "Gaijin", being so that the word is used in a derogitory way to cause ill feeling, kind of like "African American"...
My 2c... what do you say Demon Dave?
Rezz, right on the money there.
That pretty much sums up the word gaijin as far as I understand it. By the way, if you want to use a more "polite" term, use Gaikokujin... :)
Generally though, most foreigners refer to each other as Gaijin's anyway! :)
just wonder how the drag strips in japan are?
I notice they dont spray much traction compound(im not sure just by watching videos),and the strip itself looks like a normal road. This must be good for street radial tires but bad for full slick drag cars?
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
