  • Replies 50
got a confirm from the guys for the 31st today.
not sure on winton or sd for cup day. sd will be easier.
surely you can give em a call and get some bank details or pay on the day....
check, money order...wtf
If you wann enter on tuesday call Darren from FFCC on 9701 6171
Or I emailed him on [email protected]
He's the racing co-oridinator. I'm paying on the day and scanned and emailed him the entry form. Much better. :thumbsup:
Now come on 25's!
trying to get along to winton instead.
you should get 25's easy with those tyres.
Well my best before then was 28.6 with work semi's and 25-30 less rwkw's. Plus the semi's were 215 fronts and 235 rears. I have 245 all round now.
Come on sau. I don't want to be a lone ranger out there...
Awww....Don't worry about it Russ....I did the HSVOC PI day last month and was the only SAU member there......and before anyone asks the only reason I did it was for convenience :D Anyway was fun without having some RP prepped GTR setting the times :)
Hand timing is a bit agricultural.
Not hand timing as such..
What they mean is a button is pressed every time a car crosses the line and car numbers are allocated in the computer.
It's getting a bit dated but it's actually not too bad for accuracy against our in-car timers..
damn it was hot work out there yesterday.
everyone was well behaved, first time in a while were no one is going to have to pay out for a wall.
winton test day this friday...hrm. there is no way im getting work off...maybe.
You're a machine!
how'd you go guys? was in wet in melb?
just got back from winton. sunny and dry track time for every run. nice and warm up there as well.
talk about a differance in cars. from the rent a car daewoo to ex v8 super cars and group A.
Well Dane didn't go well. I'll let him explain. I think he needs an RB20 though :P
The day was poorly run and I only got 2 sessions. Just too many cars and they had long sessions. Like 12 laps or so. Meant a lot of waiting. Dane and I finally got on the track at 12:45!!!!!!!!!!!!!!!!!!!!!
We didn't have rain at all. There was rain in the morn before I got there.
Anyway after bedding in brakes etc I managed to get a 1:24.91 with a slightly untidy lap so still can go quicker. I'm very happy and again these AO50s are great. Love em. Wearing well too! It's good to see lap times come down. nearly 4 sec too! (Prev pb was 1:28.6)
Oh and I also got the priviledge of doing a rick kelly from the kink to dandy corner. 1 full anti-clockwise spin through the grass to rejoin just before the left hander. :P
Backwards at over 100k's was scary knowing the wall was right there!
Awesome stuff Russ, told you you'd do it mate! :P
Glad you made it through the spin too mate... wowzers.
As for my car, gosh darn built engines is all I can say. Oil on manifold forced me to come in after 1 lap, which is lucky I did as I have a water sealing problem so water in the oil. Engine is coming back out this week and going back to the engine builders to find out what the issue is.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
