Just had a second hand R33 GTR engine installed 3 weeks ago. The car was driving perfectly until last night when I got home - my big end bearing is shot. Some say just replace the bearing and the crank (if the crank needs replacing - $1500), others say rebuild the whole engine (5k) and possibly go the whole 9 yards with forgies (10k). My first engine blew 5 months ago from a failed oil pump and I only got the car back 3 weeks ago, this 'new' engine blew because - well I have no idea actually, was only running 0.8 bar. So I would like, once repaired, for this engine not to blow up again. I would also like to know where I should take it (preferably hills area or western subs) for these repairs. I dont want cheap and dodgy and I dont want somewhere that charges unreasonable rates - a happy medium. Thanks in advance if anyone can help a guy thats just about had enough of a car he has only owned for 8 or so months.
https://www.sau.com.au/forums/topic/291819-big-end-bearing-gone/
  • Replies 50
Unfortunately the answer is really dependant upon how much you want (or have) to spend. These cars can be brilliant fun but they also rip your heart out as quickly as any female.
When my big end bearing spun I went the forged internals route. It cost a lot and the car was off the road for a long time but I didn't want it to happen again. Going with stock internals can again you always run that risk. After a lot of research and asking advice on SAU I decided upon the following formula:
CP pistons & rings
Tomei conrod bolts
Tomei 1.2mm metal head gasket
Tomei oil restrictor
Tomei sump baffle kit
Tomei poncams 260 9.15 lift + pulley set
R33 GTR gasket set
R33 GTR long nose crank
R33 GTR harmonic balancer
ARP head studs
SARD 700cc injectors
Nismo fuel pump
Nismo AFMs
Nismo timing belt
N1 oil pump (if I had the $ I would get either a JUN or Tomei pump)
N1 water pump
HKS GT-SS turbos
HKS dumps (I think most on SAU rate the Trust ones more now)
Splitfire ignition coils
Apexi PFC + HC
I can't recall what brand of valves & springs I used right now but you get the picture anyway. It costs a lot!
A cheaper alternative could be to look through the for sale section and see if someone is selling a rebuilt motor that has forged internals. I sem to recall seeing one for $8k a while ago and there are a few people abandoning big hp projects or wrecking GTRs atm.
Good luck.
There's a lot of cost saved there already then! If it were me personally, I'd rebuild it, then you know it's strong and can take what you throw at it. You have to ask yourself though, what's the car worth to you and will you have it in a years time?
Didn't you have a recent thread asking rebuild or low-km motor and everyone said rebuild?
Yeah that was when my first motor blew, which was 5 months ago. I just got the car back from the workshop 3.5 weeks ago. The place I bought it from gave me warranty to replace the engine free of charge with a 33 gtr engine or rebuild the 32 one with forgies at a cost. I was pushing for the rebuild but the option was then removed and I had no choice but to replace the engine. Either that or take the car else where and pay full cost. I thought I might as well use the warranty while I have it...but now back to square one again with no warranty. I have had some pm'ed proposals for rebuilds that I am considering at very decent prices - just gotta pull a bit more cash together and get started.
hopefully the standard r33 crank isnt damaged and can be used again (with the usual preperations) that'l save u abit of money just there
you aiming for a big Hp engine? or something reliable that can handle up to 300rwkw ?
maybe a basic forged rebuild would be ideal...
Yeah I hope the crank is ok. My car dynoed at 230awkw at 1 bar and I was completely satisfied with that setup.
Does anyone know how or why bearings break so easily?
even if it is damged a simple 10thou grind and oversize bearings will have it like new...as long as its not too deeply scored.
my basic rebuilds using only forged pistons, ARP rod bolts and Nitto oil pump (everything else Nissan)have been proven reliable at over 450AWKW. The basics put together well handles big power...no problem.
Edited by DiRTgarage
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
