  • Replies 50
plan for the worst.
turbos, and crank and oil pump. and if you dont need them then thats cash in your pocket.
Turbos have been rebuilt 2000 clicks ago by garret. brand new N1 oil pump has also only done 2000 clicks also. I will get them inspected regardless though, still gotta grab some cash etc.
i would suggest repairing the crank/new bearings
new decent oil pump (jun, nitto, greddy, tomei etc etc)
valve guides
sump extension/baffle (greddy the best bang for buck)
full nissan gasket set
and new rings
if you have more money chuck in a set of decent pistons and either arp rod bolts or a set of spool rods
and if you want to spend even more it will snowball and you will be up for around $20k
as dirt garage said you could quite easily use your stock rods for the build as they have been proven to hold the power. but if you have to buy a few new ones it'll work out cheaper going spool rods.
second set of rods = $200
resizing them $120
ARP rod bolts $120
the look on someones face when you make 467AWKW and run countless low 10's with them....priceless
i honestly doubt spool chinese rods would be stronger than stockers.
Edited by DiRTgarage
I'd take you up on that bet. $5 says they are stronger tuan the stickies.
Captain Metalurgy agrees with me too.
People just underestimate the stockies, that's all.
I will be taking dirtgarages advice for the rebuild, he is very confident in what he says and he has the cars to back it up. Just have to sort some things out first before I can proceed. Although I must admit my faith in the stock motor is wavering after my experiences. I am hoping it is human error and not engineering.
its unfortuately the fact you have no idea of the life the new engine had before you recieved it that has to be considered.
metalurgy yes...but have you taken into account the cross section of each item.
Id say we may be getting $2.50 each.
Sounds like a round at the pub to me
Either way, I've got a set of Spool rods you are welcome to dispose of for the test.
Have you got any standard rods you can part with? Would only need two
wtf? double post?
$100 tells me i can hear Noel telling you to get off the net and get your ass back in the engine room assembling 3 x RB26's.
I win!
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
