  • Replies 14.2k
wrong, this is gayer than aids
Who is that? He looks sooo dreamy... :ninja::)
Well, i know what i am going to be doing over the next few days...removing my 6000k HID kit, even though i have other things on the car i need to be more concerned about now :)
can you get caught speeding from a car camera on the opposite side of the road?
I seem to remember something about it being illigal for a camera car to flash in front of you as it could distract you or something so im going to say no you cant get caught speeding from a camera car on the other side of the road. Any one else know?
ahaha i saw the add for that story, had it aired yet? They clearly have nothing better to do if there covering the dangers of HID globes lol...
Well im going to sinergy friday could they hook me up there?? Im guessing they dont have it lying around :ninja:
You're best up taking Mitch up on his offer
there are 3 things that could be a problem
a) the horn mechanism, b) the horn itself and c) the fusing/cabling between (unlikely)
in either case the easiest thing to do is remove either the button assembly or the horn and see if that fixes the problem - its probably the horn though from the sounds of it, so take ur current one out and swap with mitch's and see if that fixes it.
otherwise, i plan on upgrading to some earthshaking horn in future cos im sick of a wimpy sounding horn so i might sell ya my 32 gtr's if ur still desperate in a couple months heh
-D
Ah cheers Ben. That clears things up :ninja: Ill send you a Pm Mitch when i have enough posts lol
I might be desperate in a few months well see how it goes
Edited by Terence-T
lol and TT said the car must have an auto washing device fitted to squirt onto the lights? wtf?
yea pritty sure they need to be able to self clean the lense.like a little wind screen wiper on the headlight so if they get dirty you can clean them so if something gets on there it wont difract the light and cause glare.
Mitch are you selling any interior bits?
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
