  • Replies 14.2k
might be ablet to get you a cheap rb25det gearbox ;)
haha wud still love to see what its like.
combine the 2 :) making the ultimate time machine
the vid does mention them making upgrades to suspension and engine. however stainless steel would be a heavy. would it rust though? what u do when u need a respray :happy:
wayne, go an see troy at tyrepower. he'll price match. and you dont have to pay shipping + fitting and balance on top.
steve, again, call up a shop like tyrepower and ask them for an honest no bs answer. 15-20,000 maybe.
also just got my qfm pads, paid for them over the phone yesterday at 2 pm, postie came by 5 minutes ago with them.
Edited by scandyflick
Will call tyrepower, I'm going to need a couple fronts pretty soon.
Which pads did you get Dave, HPX or A1RM?
The KU31's I bought are on the back. My fronts have the insides chewed out now because of incorrect toe! I'm thinking of going for the HPX pads, not going to be tracking my car :)
tasty.
a1rms are still good cold, but they still work when they get hot. ive already overheated my 450 degree acres once.
Any tyrepower in particular lol?
i think theres one in salisbury. try them.
... adelaide you tit.
Same, the hpx sounds like a decent, relatively dust free street pad
weezy - teins are pretty decent, ill know after this weekend if I want to buy them but so far so good...
-D
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
