  • Replies 14.2k
What size rear has the turbo got Abe?
I think the Garrett 3076R(3037S) is a 0.82
little bit of a lean spot there at 160kph....just monitor your knock count
Are you talking about the 262kw graph or the 149kw graph?
If the 262kw graph, if i am not happy with the tune i can take it back and get it touched up for free :), he didn't really have much to go with as it was a whole new tune, so he got it to where he was happy with it and gave it back to me. If there are some niggle bits i am not happy with, he will sort it out, see how we go on the way to Loxton. But i will rarely be driving at 160kph, if at all.
u can see the lean spot in the first 149kw graph that you posted. there is a big drop in the afr line.
ur new tune looks good :)
Ah...well the 149kw graph is stock...stock everything other then a podfilter.
just bought an RB20 + gearbox + FMIC + ecu, afm, loom +3'' zorst for 1100.
bargain? yes.
entirely happy? no its missing .5 of a liter in capacity but oh well, its a budget build.
specially when its gettin fitted and wired by a effing champ in swaps for the RB30 :)
cant wait.
pretty keen to build it up in almost every area, inherited some pretty average suspension in the car so probably looking at coilovers as my first upgrade. gunna go for the BC br range i recon, cant seem to find any negative feedback on them and they are sweet price.
buy decent quality straight off the bat. please. save for an extra week or 2 and buy cusco's or something.
.82 rear, thats why its a bit laggy, but u got more topend out of it
since u cant check ya knock level reading just keep an eye on ya engine warning light, if it starts to come on regulary after a boosting hard step off and getnya tuner to check everything again (timing)
bargain? yes.
cant wait.
nice deal Graig
and who is this CHAMP that is wiring it up for u??
fair enough, might have a look into it a bit further. im normally pretty keen to do everything the right way. to me these coils looked like a fair deal.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
