  • Replies 14.2k
.82 rear, thats why its a bit laggy, but u got more topend out of it
since u cant check ya knock level reading just keep an eye on ya engine warning light, if it starts to come on regulary after a boosting hard step off and getnya tuner to check everything again (timing)
I am not really fussed, still picks up speed quick, boost hits like a train...which is rather interesting, first few times i did it, it was like when they hit the NOS in Fast & The Furious :) .
Since it is more laggy now, does that mean i am going to get better fuel economy when just dribbling around town?
Not so much at 160km/h but the revs at which point on this garph it hit 160km/h if you know what I'm saying.
yeah I was only using kph as a reference for the graph....load on the road could lean it out at any speed
As a rule of thumb 14:1 at idle, and depending on your timing and amount of brake on the rollers 12:1 is the leanest I'd ever go up top.....11.5:1 is a bit safer as long as everything else is taken into consideration.......we're talking pump fuel by the way.
mate dont worry i no what its like to have a laggy turbo and thats on a forged eng. i have garrett gt3540 on mine
and like yours when boost hits it hits HARD!!!!!!!!
i love it
ahhahha my fuel economy is shit and thats rarely boosting it
I am not really fussed, still picks up speed quick, boost hits like a train...which is rather interesting, first few times i did it, it was like when they hit the NOS in Fast & The Furious :thumbsup: .
Crank up the boost to 18psi and feel the hit :)
buy decent quality straight off the bat. please. save for an extra week or 2 and buy cusco's or something.
It has been suggested on these very forums that the BC coilovers come out of the same plant as the Greddy coilovers. I'm not entirely sure whether it's true or not.... but either way the BC coilovers have springs that are too stiff for my liking!
I really do wonder, what exactly drives people to do this.
Also, why 49?
Doesnt help when your girlfriend posts what you've done over her Facebook status updates like Dan showed us!
i think krish is making similiar power to you abe. about the 250rwkw mark.
Yep making around 246.6 rwkw on 14.5psi....needing a new exhaust as when we cranked the boost up to 17psi at 400rpm it starting dropping off to 14psi and held hard on 14psi....for some stupid reason the boost wont go higher then 14psi so we ie me and the tuner came to the conclusion of needs a new cat back system and also have to get andrew from AM Performance to fit it all up as there is a leak out of the vband flange thingy
I am using a .63 rear housing so my boost comes on a bit earlier then yours Abe but has the same feeling of hitting you like a damn train when the boost kicks in.....well described with the FnF NOS scenario....cant wait to check it out tomorrow
mine is at boostworx right now, tuning the AEM FIC-8 ecu.
235kw at 5850rpm but not reving past 5850 at all - Im sure its a setting in the program,
I have made my suggestion re calibration to the tuners, so hopefully a little later I'll get the good news that all is fixed and well, reving thu to 7250rpm as per the remap chip.
the AEM FIC-8 looks great: here http://www.aempower.com/files/electronics/...lease080728.exe
for $350 off ebay its a massive score, considering the safc/sitc sold for $300 before they were even off the car! ;)
Hopefully my thoughts re the tune program setup work, and she free revs again into the red zone.
250kw
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
