  • Replies 14.2k
is that boxxy?
boxxy makes me wanna stab my eyes out with used (preferably diseased) needles.
potentially nsfw, danpat (avatar chick).
boxxy;
Edited by scandyflick
fur shur
but boxy has her own hit singles :( such as I AM NOT TROLLLLLLINGGGGGG
still the most annoying thing i have ever seen.
and i work in hospitality. thats saying something.
you know what i love about SAU?
it works.
yeah, noticed hardlytuned was down again.
i dont know why people crack jokes about the hardtuned name, i think it suits it perfectly, like a hardtuned SR, never reliable, always breaks, but when it does work, well even then its still pretty shit :(
Come on mate thats a bit harsh, it works for atleast 5 minutes everyday, cant go asking too much :) :)
Edited by DR JOSH
sau sa bushfire warning
horrible day out in the hills
if you see a car on the side of the road, ppl smoking etc flicking out butts - take down the rego number.
you never know...............
