  • Replies 14.2k
is that boxxy?
boxxy makes me wanna stab my eyes out with used (preferably diseased) needles.
potentially nsfw, danpat (avatar chick).
boxxy;
Edited by scandyflick
fur shur
but boxy has her own hit singles :( such as I AM NOT TROLLLLLLINGGGGGG
still the most annoying thing i have ever seen.
and i work in hospitality. thats saying something.
you know what i love about SAU?
it works.
yeah, noticed hardlytuned was down again.
i dont know why people crack jokes about the hardtuned name, i think it suits it perfectly, like a hardtuned SR, never reliable, always breaks, but when it does work, well even then its still pretty shit :(
Come on mate thats a bit harsh, it works for atleast 5 minutes everyday, cant go asking too much :) :)
Edited by DR JOSH
sau sa bushfire warning
horrible day out in the hills
if you see a car on the side of the road, ppl smoking etc flicking out butts - take down the rego number.
you never know...............
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
