  • Replies 14.2k
I have nothing against rotary engines, in fact I love them and the sound they make, but I have to agree with the whole 3.9L displacement argument as each rotor has 3 combustible sides to it for every one rotor revolution (not crank or eccentric shaft revolution).
Yeah that's true but only one side of the rotor get's used per revolution of the output (Eccentric) shaft so there for only 1.3 litres (0.66 x 2 for a 13B) gets used per revolution. You need to forget about the revolution of the rotor becasue everything is measured (RPM and Power) on the output shaft on every engine. You never see a piston speed gauge on your dashboard do you. It's like saying that the rotation of the cam shaft is vital to the running of a 4 stroke engine so really the redline of our nissan engines is really around the 3750 rpm mark.
what is this? i know its a drive shaft.. or is it drive shaft AND tail shaft....
it come out of teh vl with 20, so is it specific to vl rb20 or will it suit 25, 30, R31's etc?
sellin it on ebay thats all :laugh:
Edited by craig R33
the output shafts for RB30e and the RB20 gearboxes are the same so it's a VL tailshaft and will suit anything with either of those GB's. I haven't mentioned the 30et's because i'm not sure if the output shafts are the same, as i'm lead to believe that they had a stronger box so they may have a different output shaft.
Edited by D_Stirls
go for it, what have you got to lose. It's much the same as just pulling the engine out and putting it back in with the nissan stuff as it's all pretty modular.
My conversion for instance;
RB25 > S13
-Use a Cheffy X member that bolts straight up to the S-Series chassis rails.
-Then use RB20 Engine mounts brackets, that bolt straight up to the 25
-Use some off the shelf rubber mounts (i have some ideas here but we'll see if they will work and or be an improvement on the RB20 mounts.
-The only bit that has to be custom made is the gearbox X-member, which is no problem for me and infact i'll be making up some CNC brackets that Matt can then sell.
-Almost forgot the custom tail shaft which will cost $250 for an engineering fabriction place that makes tails shafts.
There you go the mechanical part is done.
Edited by D_Stirls
Stolen from ns.com but lol's all around... Fast and the Furious-styles.
ive seen worse ones, that are obviously made up,
one of a skyline i think that was "going too fast for me to get the number plates" or "car was drifting behind me so i pulled over because i was scared"
so, had a couple problems with the 200 at the track day;
http://www.skylinesaustralia.com/forums/Fu...ge-t293848.html
any help would be rad.
EDIT: luke loves the buttsecks
Edited by scandyflick
pathetic
while im all for a laugh, this is about 12 months too old
-D
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
