  • Replies 14.2k
Yeah no shit hey. Trying to find out about catch can setups/ oil mods for some piece of mind and just when I get some useful info someone two posts down trashes it.
All I want is a lightly tuned reliable GTR.
  • Oil mods like which catch can, relocator and oil cooler
  • Front pipes (No I'm not going to AM Performance
  • Pods or panel filters
  • clutch, ebc, injectors, cams, fuel pumps.
Too many options, too many chances of buying a brand thats not going to work well.
It's simple, there's ASSLOADS of recommendations out there. Easiest way to pick what works, go to the RB26 dyno thread, compile a part list, work from there. That way you know what works and what doesn't.
As for your list...
[*]Oil mods like which catch can, relocator and oil cooler - JJR Autech catchcans are the trick, simple, cheap, easy
[*]Front pipes (No I'm not going to AM Performance) - If you're not going to listen to heaps of people recommending you see Andrew, I won't answer this, he is cheap, does quality work and his service is second to none
[*]Pods or panel filters - Standard air box is good for 400atw, it also lets a shitload more cold air in through the air guide, do the math
[*]clutch, ebc, injectors, cams, fuel pumps - Clutch; a nice twin is my opinion but that's personal preference. EBC; anything like the Profec B or the Blitz SBC. Injectors; 700cc Sards, straight drop in, easy as (although not needed if keeping standard tubos). Cams; not needed. Fuel pump; I prefer the Nismo for straight drop in but you can get by with an 044 or 040 Bosch
There you have it, a nice, easy, reliable part list.
I pretty much agree with everything that Heslo said.
For an oil cooler get one that sits in the brake ducting rather than in front of the radiator.
As for cost buy from Japan - Nengun, Greenline, Perfect Run, Import Monster or RHD Japan. With the current exchange rate against the greenback check out some USA sites as well and see how they compare.
There is soooo much info on what to do with an RB26 on SAU that you can get lost but you will soon figure out who knows what they're talking about. Most of the oil mods won't happen until you open the engine so start saving for it. Until that time stay off the rev limiter and put an extra litre of oil in for track days or if you intend to do some launches.
:P So Chad, whats it like to drive a 300kw monster on the road
Entertaining! Just make sure you have good tyres, I'm running crap street rubber atm and the hills scare the crap out of me. 3rd gear plus boost = sideways, even 4WD does not help :P
may i ask what rubber? kumho's im guessing? have u ever tried the toyo t1r? if so, how does it compare?
-D
any one had any experience with fitting these?
i want to run it with this
in one of these.........
fuel tank in there atm hasnt been used in 3 years, so i hate to see the shit in the bottom, also
need to replace fuel pump anyways....
from what ive been told craig, you'd need a surge tank with that setup as well
the only fuel cell ive seen that doesnt require that is a polycarbonate model from autosport, which im purchasing for the 31 for circuit
-D
Think of tyre brands most people haven't heard of before, I never buy good street tyres, i just use second hand crap. It makes driving more fun :P
iced cofee?
correct. well played.
sigh, dont get me started on IC atm..... coles have them for $1.44...
so when i did shoppin thurs night, i bought 15 of em
saves me buying one a day at 3 bucks....
in theory, they should have lasted me 15 days right?
wrong, i have one left.
and f*k it ima drink it nao
Hey Craig, Trent replied in that 17C thread you started in the Forced induction section, Seems it's a bit laggier than first thought with full boost (21psi) @ 4800RPM. That makes it as laggy as a TD06SL2-20G which would put you over the 300kw mark. I guess the old tech' compressor wheel isn't as efficient as the new stuff.
Edited by D_Stirls
Yeah i'll take it, i'm planning on buying a stag' next year so i'll either use it on that, or clean it up, put a kit through it and see if i can make some money selling it on NS, here or on Ebay
Edited by D_Stirls
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
