  • Replies 14.2k
So who knows there RB26's back to front? Gonna need to know what im missing etc sooner or later to get it running. Got a whole heap of parts arriving soon for it and not gonna know what im missing besides the obvious stuff.
Cheers.
Cheers.
pistons are really good to have ay
-D
im cara
26/immature/shit talker/attention seeker/ruins other peoples lives
Hi Mitch & Cara,
I'm David
35/mature/non-shit taker/attention avoider/(parts of) life ruined by other drivers.
Who's life have you ruined? Did it involve witchcraft or voodoo? Are you getting better at it? I think there may be a business opportunity for you, similar to a 'cooler' at casinos.
Hi Mitch & Cara,
I'm David
:P
Hi Mitch & Cara,
I'm David
hah that has the good makings of a road safety initiative commercial
"Hello, my name is David and I'm a non-smoker.." (Bill Hicks fans will get the Yul Brinner reference)
-D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
