generic china spec 600x300x70 delta fin core. basically exactly the same as what i had, and it performed pretty well.
Nice. I had been looking at return flow (is that the correct term) fmic's but now I might spend the $$ elsewhere!
  • Replies 14.2k
^straight pipes into twin staggered tips!!!! ladies will throw there vagina's at you
i was thinking something along the lines of luke (heslo's) system actually. we'll see. depends how much damage is done to the exhaust, if its just the rear pipe thats mangled (centre mufflers always been a bit dented) then ill have twin 2.5" s/steel pipes with 3" resi tips thrown in behind the centre muffler.
if its completely naffed, ill probably get a kakimoto from jis.
I hear ya Dave, not racist, but ladies of african american background and ladies of the orient - do not want.
glad im not the only normal one. while i dont exclude them completely, ive made 1 exception to my rule, and that was over 12 months ago.
its funny how many people at work have yellow fever though, bugs me out a little bit.
nice and shinnyyyyyyy
Well someone was definitely happy about it.
Like this?
I did a search on Google Images for 'ladies throwing vaginas' and this page came up. Scroll down a bit for the cartoon.
african american/asian
^I'd smash that :banana: :banana: :D
Hi Mitch & Cara,
I'm David
35/mature/non-shit taker/attention avoider/(parts of) life ruined by other drivers.
Who's life have you ruined? Did it involve witchcraft or voodoo? Are you getting better at it? I think there may be a business opportunity for you, similar to a 'cooler' at casinos.
well apparantly i have ruined many lives because i have major depression
now you go telling me why you would say that to some one who has depression, yet this person says that they are here to support me and help me,...............
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
