  • Replies 14.2k
Just found out Ruby Rose is DJ'ing at one of the Sensation White Deluxe rooms on new years.
f**k yeah.
I couldn't care about what she's mixing, I just want to meet her. f**king hot as carpet muncher.
f**k yeah! Ruby Rose is mint!
That's what i was going to sell mine for
Oh well since he has one already organised i guess I'll keep mine for a little bit longer.
Just a quick heads up to anyone else that was thinking about PM me about buying my 180 for $3K. I was only kidding, hence the italics.
EDIT!!
Is it just me or has NS just disappeared?
Edited by D_Stirls
EDIT!!
how many said, "hey mate would you take $2800?"
We had a minute silence today. It was all properly done as i was in the defence force recruitment offices since 8am today.
I wanted to be a pilot, got told no. FARRRK!
so they offered me to be a marine technician on those submarines.. might do it.
NS used to be solid as a rock then about 12-18 months ago when it was down for 5 days straight it hasn't been the same. Loz' is working for PWR now so i don't think he has the time to dedicate to the site that he used to. and the new version has sucked ever since it was launched, they haven;t fixed any of the probels that have been listed on the Beta page. i know nothing about building webpages but surely it wouldn't take 12 weeks to fix the niggly little problems.
Surely the site pays the bills for him! What has become of the Project Car? Havent seen or heard of it in ages.
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
