  • Replies 14.2k
Craig, its probably a 15 year old kid waiting for his pocket money to come. The "bank" ie mum and dad, will not give him his pocket money, until he eats his vegetables. :P
Ye Cant have anneh puddin until ye'v had yer meat!
How can ye have anneh puddin if ye dont eet yar meat!?
-D
ugh. fail.
worked 11 days last fortnight. including both fridays and saturdays. on a new agreement that earns me an extra few cents an hour + 4% nightshift loading, and yet i barely earned more than i would working 8 days. i dont see how in hell i can work an extra 24+ hours and only earn an extra $150...
ugh. fail.
you may have jumpped up a tax bracket...
dont forget classic adelaide rally starts tommorrow, well it starts today but u cant watch that section
spectator guide
http://www.classicadelaide.com.au/assets09...iew_09_9Nov.pdf
any of you lucky buggas got time off work?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
