  • Replies 14.2k
pretty sure andrewjzx100 wants it
Yep, that 20 is mine :D
Just went and got the car running so I could drive it to my mates for the swap and I must say boost is good fun after driving around in nothing but a 70s Cressy for a month and a bit :thumbsup:
Ok, well I had my RB20 compression tested this morning and:
1: 92
2: 88
3: 80
4: 85
5: 90
6: 90
So obviously not too good. It's got oil in the water but Ive been told its likely un-related to the low compression as its across the board, not just 1 or 2 cylinders. My mechanic told me its either due to valves not sealing, or the piston rings. So realistically, where should I go from here? Please spare me the comments about selling it or converting to a RB25/26...
Rebuild. Or replacement. Doing a huge, expensive rebuild is pointless on a RB20. If you're going down that path, RB25 it.
Was the low compression from the blown turbo then?
Edit: scrap that. Just quad-rotor it. Cummon. Do it. Or 20b it. Do it. I dare you. No. I DOUBLE dare you.
Edited by CRoNic...
Yeah I do agree on the huge rebuild thing, but I'm not sure what you mean with the blown turbo... I thought it had a blown turbo - but apparantly not, there is a chance thats gone too though.
If your going the sensible route, grab an RB20 block and drop it in, will cost you f**k all and youll be back on the road sooner.
JIS have an engine, loom and ECU package for $1950, grab it, sell off the loom and ecu, sell your f**ked 20 for peanuts, some parts could be valuable to someone else.
Or JMS have an R32 front cut, no gearbox, low kays for $1500. Grab it, keep donk, sell parts, ??????, win.
RB24...that is all :thumbsup:
Oh right, I just remebered reading that you thought you blew the turbo on that Berri trip a few weeks ago? So it was actually something worse?!
Yeah I thought I blew the turbo, but further investigation points me towards the motor, and then the compression test confirmed it. Like I only discovered yesterday when I was pulling the crossover pipe off to do the test, that Ive got oil leaking everywhere (both valve covers, pcv valve etc), but the crossover pipe was dry..
I am quite tempted to go the RB25 route (just got off the phone to Paul from AdelaideJap), but I really dont want to go in over my head so I'm clinging to the 20 still.
I'd love to build an RB24, but everything that Ive read suggests this isnt the cheapest thing to do...
I was talking to Adrian about his 25 swap. He regrets the swap because the 20 can take abit more abuse.. but you get better results from the 25.
All depends on what you want from the motor and what you do with your car.
I don't know how much it would cost...but 2-2.5k should do it, ill scan a article out of HPI #44, where they start building a RB24, and send it too you.
The 25 is a better long term solution, and it'd be less labour involved I'd imagine - would be a better starting block for engine mods too, cause that extra capacity really helps
-D
mate i've just being driving an automatic hyundai getz around cairns for a few days and let me tell you what a heap of shit! Gutless as all f**k as well
LOL sounds like the one I drove in the Gold Coast, couldnt farking stop , couldnt get it to go.
boot space less then the R34... what a joke of a car. (it was even brand new) disposable car
-D
that it does Ben...Dion i know you want to drop a RB26 in there mate....do that instead
thats tuff luck dion, damn old cars
on the subject of old cars, check out this 240 :)
http://www.carsales.com.au/all-cars/privat...6&silo=1011
you got that cash lying round dont ya
Edited by Inline 6
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
