  • Replies 14.2k
Yeh, which Ben built from the ground up with the help of my bro, and other mates. I was there most of the time lending a hand where possible.
Miss those days
the car looked a million times better when ben had it then now that its just a un-cared for drift hack
when he asked me to help a couple times i didnt want to touch it, it was just so perfect lol
pics of my old shitter and what amazing looks like lol VVV
i seem to get a fair bit of bubbling noises outa my car when i switch it off in this weather.
tripple checked the coolent levels after it cooled down and they seem ok, temp gauge seems pretty happy to while driving :) strange cars
Mine actually wants to stall sometimes when I get off the throttle, it only does it sometimes and that's only ever when the AC is on!!!
any one wanna add to my work van fixing fund?
Problem #1... put diesel in it when i picked it up, didnt start, had to wait half hour for it to ''cool down''
Problem #2...smashed the rear window on my gate when i opened the door
Problem #3... scratched the Mc'fek outta the insulation on the side walls while loading in the crane.
Problem #4... dented the refridgeration unit with said engine crane.
Problem #5...leaked about 3 litres of engine oil all over teh inside floor.
wasted 9 bucks with the high pressure hose trying to squirt it out, sorta succeeded.
oh and dont forget the speeding fine i got on the way home, 67 in a 60 me thinks :P
I REALLY HOPE YOU APPRECIATE THAT CHEAP RB20 WITH ''FREE'' DELIVERY ANDREW!!!!!
Off to nissan tomorrow to get prices on the following. Hope i get change from 1500.
• Timing Belt
• Water pump
• NSK timing belt idler bearing
• Tensioner Bearing spring
• 2x Cam seal
• 1x Front crank seal
• NSK timing belt tensioner bearing
• Thermostat
• Fuel Filter
• O2 sensor Part numbers? Front and rear
• 5x Exhaust manifold studs
• Cam cover seal
• Throttle body + Plenum gaskets
• Front diff housing gasket?
• Oil filter block gasket
• Rear crank seal
• Coil pack loom
• Alternator + Power steering belts
• 12x exhaust manifold washers
• 12x exhaust manifold nuts
• 4x turbo to manifold locking tabs
• 1x copper crush washer kit
• 1x oil drain to block gasket
• 2x oil drain gasket.
anyone want to donate to my winch fund?
im sick of pushing busted cars onto my trailer............they're fecking heavy LOL
i'd be happy to help you out at some point, but not sure how much i'd have till the cars back on the raod =\
Timing Belt $80~
• Water pump
2x Cam seal $44~ ea
• Thermostat
• Fuel Filter
• Cam cover seal
• Rear crank seal
• Coil pack loom
Alternator + Power steering belts $30ea~
• 12x exhaust manifold nuts << they are m 1.25 thread , just go to an auto shop and get a pack of tensile ones , way cheaper
hope thats some help , thats some of the stuff i bought for mine :)
haha
should ask more people to break down :)
eh, i'll put off a small spend on the 31 f*kit
appreciate it david, cant have these girls getting the wrong idea
I'm here to help. Your previous statement was going to create extremely high expectations that mere mortal men wouldn't be able to live up to. And that just creates disappointment. Now the ladies expectations have been lowed to the point where all you could possibly do is exceed them.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
