While we are on quick questions lol
Im looking at getting an RB25DET engine package that used to be an auto, will this matter for me? (going into R32 as a manual) I know you change the flywheel etc but what about the ECU...
  • Replies 14.2k
you can use an Auto ECU with a Manual but not the other way around. The only thing that will be a pain in the ass will be getting the auto sp.i.got boss out of the end of the crank but it can be done. you will probably need (well it'll be easier) a manual loom from the trans to the EB relay box but you can adapt the Auto one if you want to.
Quick question..i know you can buy a trans cooler for your auto..can this also be hooked up into a manual transmission?
As for the Trans cooler question, no you can't because there is no pump to move the G/Box oil. With an outo it is basically a big pump so there is a pressure feed to push the fluid through the cooler but with a manual they rely on contact transfer to move the oil through the box and there is no pump.
In race cars that need a cooler in their manual trans's they run an external pump to move the oil around. They also run a thermostat as the oil needs to be allowed to get up to temp.
Why are you thinking of fitting a cooler to a manual trans, they don't need it unless your doing long stints (1hr+) on the track?
Edited by D_Stirls
Thanks DStrils, if I get that one I may aswell just get another loom because they are pretty cheap. The reason it caught my eye is auto and 81k say tight motor to me...
edit: Had an epic dumb moment, its late ok :D
the engine looms should be the same it's just the loom that runs down the drivers side of the engine that the alternator, oil pressure switch, transmission etc run of that's different.
Edited by D_Stirls
Main reason would be just to keep the manual box nice and cool. Im not exactly awesome with a manual, due to lack of experience, and wouldnt mind having some kid of insurance so i know that the box wont be rushing hot oil and such. I was just thinking this because i remember seeing the trans coolers on the gtr z-tune, and whilst looking pretty scmick, makes sense to me.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
