Shouldn't need replacing. They're brand new ISC N1s. Well according to Ryan hand tightening the bolts isn't enough and a rattle gun needs to be used.
all the bolts on my coils were tightened with an 18" breaker bar. the only knocks ive heard were from my wheels getting touchy feely with the inner guards. once i removed them i didnt have a problem.
  • Replies 14.2k
whats it sound like exactly? a heavy metallic sound id be inclined to say the coilovers f**ked. if its a sorta dull thunking, id say a bush or maybe a stretch, an engine mount (thats what my problem was a little while ago, was worried it was a coil, it ended up being a naffed passenger side engine mount).
ugh.
http://www.news.com.au/adelaidenow/comment...54-2682,00.html
how long til this is abused?
Edited by scandyflick
I'm in need of a cheap run around car by not later then Sunday.
If anyones got something, let me know ASAP as I just want to get a car and be done with it so I'm sure I'll have something by Saterday.
Don't really want to spent heaps as I'll be saving my cash for my EVO when I finially find one I like.
Cheers
Does anyone wanna see Paranormal activity???
i have it here, well a ''preview'' anyways.... :)
but im too scared to watch it! lol
Twas a good movie Craig. Some nice jumpy bits in it, different than your usual "horror" flicks
You'll sleep, don't worry
The film wasn't scary at all. I watched it at home, alone, after midnight, with all the doors and windows open and the only thing I was worried about was when the scary stuff was going to begin as the movie was ending soon. It didn't.
You may risk falling asleep before the movie ends. Double thumbs down.
What's this Feedback button on the right of the screen?
LOL so it's not just me. I saw it and was just like what the fk is this shit :D
On another also humourous note - the muffler fell off the cressy this morning :D Sounds beefy as now hahaha
On a less homourous note, I believe the crank is bent in my new RB20. Yay for never ending problems, time to get out the matches and petty I think.
Edited by AndrewJZX100
LOL.... so true :P
cept when ur boardroom is fitted with ceiling microphones and a 2-way video teleconferrencing system that can be turned on via remote from Head office in sydney at anytime without anyone knowing......
On another also humourous note - the muffler fell off the cressy this morning :P Sounds beefy as now hahaha
WHAT??
if you find it is, let me know asap, i know where this mothr-fkr lives!
prick told me it was all sweet!
None of the conference rooms I've been in have that thankfully.... none that I'm aware of anyway :P
thank f**k i do teleconferrencing from my office
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
