  • Replies 14.2k
While I'm here ...
Can anyone tell me, or point me to a link, as to how a GTR/260 gearbox pull-type clutch fork mates up with the pull-type clutch kit, so the clutch engages properly. Push type I know you just slide things on. But is there a trick to fitting the GTR box to a pull type pressure plate and carrier?
Thanks >_<
while i was picking up my car i asked this qeustion today as my intention was to drop by and help.... unfortunataly i didn't sleep last night and afterwashing my car i had a quick cat nap that i only just woke up from =\
i know there a BARSTARD to get off (right matty/blue 32) =P
but apparently you can assemblem the forks and everything and then set up the thrust bearing and just "click" them into place! soooo much easier than removing them!
That's 'cos I killed the pigeon with my gas when I was changing your turbo
normally id be inclined to agree, but i didnt put the hks piping on until just before the private day.
Chuck up some specs :)
Its a 88 model was auto by the looks of it, RB20 it pretty much stock engine wise. Its supposed to has a Autech ball bearing turbo, Nismo suspension and a fairly new Exedy clutch which a cant seam to take off without chirping the rears :D It def needs moar powers as it has trouble spining the wheels in second. Rims are 15's with 205's so i'll keep them for sliding as they are easy to replace and i'll see if my drifteks fit on the front.
What should RB20's rev too? 7000?
Most definitely.
1998 Black R33 GTR series 3.
~100k km,
400R Front Bar,
HKS 2530 turbos,
18" Nismo LMGT4 wheels,
Loud. Fast. Unbelievable!
PM me if you want to know more.
dang it, i so didn't want anything to do with this thread grrrr
be more aggresive with the clutch, 20's got enough power to slide a ceffy lol
Pretty sure its just running standard boost, its not very fast atm. It may still have an auto diff as well which wouldn't help.
Sounds like awesome fun man.
I'd be inclined to rev a Rb20 to like 7,500?
God hearing about you having a track cars really gives me the itch to hurry up and convert my S13 to manual.
hmmm
Im off for a spin in the hills
wish I could sort out my ecu and get back to 7200rpm limiter
currently cuts at 6500, some sort of issue with the AEM F/IC-8 ecu I have, as the remaped stock ecu is set to 7200
meh, changes gear right in the meat of the power delivery so it isnt too bad.
surprising tho that a little 700rpm means my car is down ~15rwkw
ie 6500rpm = 240kw, 7200rpm = 250kw+ going by the dyno graph(s)
RB20's semi redline at 7000 and full redline 7500.
My limiter was ~8000rpm.
Went for a spin in my managers R33 S2 tonight lol, it did give me a Skyline fix thats for sure.
    • Robertson was a Canadian inventor, and it absolutely reigns supreme here. 95% of our screws are Roberston. It's literally the only option you can buy off store shelves. What would it have lost out too? I believe it's also very popular in the US.  My reference to imperial was pointed to both NPT and BSP.
    • No. BSP lost to the cultural/technical imperialism of living next to Trumpistan. Face it, Robertson screws were better and still pretty much lost out to the yank stuff. The Europeans hate the Brits and they don't use NPT. NPT is just as "imperial" as BSP is, being based on those useless inch thingos. Just done differently.
    • I live in Quebec. Our license plate slogan is "Je me souviens" Translated is "We will remember" as a reminder to when England conquered us and that we must never forget what they did. Long story short, BSP is unheard of here due to being an English design. I'm surprised our nazi anti english government office the OQLF hasn't kicked in my door yet just talking about it, yet alone imperial anything.
    • Thanks for that! I did a quick Google search looked up some of hydaulic stores and didn't see it listed on the website, I'll give them a ring. Also found out later that I can buy 2 oem bleeder bolts for 10 bux and come with the washer which I might do so I don't waste the money it costs in petrol to find 2 washers (already did that lol). The old copper washes look in good nick, I drove it after taking it off and putting it back on and didn't see any  Part number here for reference if anyone needs: 14053-42L0A
