  • Replies 14.2k
anyone got a spare seat in a car for the cruise tonight?
I may do, i still have the rear seat free in my R33 - GTR Seats. However if you are wanting pickup and drop off home, i can/will only do it for southerners, as it would be out of my way.
cbf with vids. Requires me to organise someone to come along and take the vid - this is beyond the levels of effort I currently have.
Probably won't drive it again until I get the HB and other little problems fixed up next year. Got other things to spend my money on like booze and a few chrissy presents to keep the missus happy and after those things I'm skint as (lots of booze is required).
i am now very happy in the pant region.
tried Dave's rims on, and actually looked less mexican than i thought....
10mm slip on spacer and a guard roll is required for the rear,
while a 5 stud brake upgrade is in order for the front...
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
