  • Replies 14.2k
anyone got a spare seat in a car for the cruise tonight?
I may do, i still have the rear seat free in my R33 - GTR Seats. However if you are wanting pickup and drop off home, i can/will only do it for southerners, as it would be out of my way.
cbf with vids. Requires me to organise someone to come along and take the vid - this is beyond the levels of effort I currently have.
Probably won't drive it again until I get the HB and other little problems fixed up next year. Got other things to spend my money on like booze and a few chrissy presents to keep the missus happy and after those things I'm skint as (lots of booze is required).
i am now very happy in the pant region.
tried Dave's rims on, and actually looked less mexican than i thought....
10mm slip on spacer and a guard roll is required for the rear,
while a 5 stud brake upgrade is in order for the front...
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
