  • Replies 14.2k
I believe "driving on the road" was likely to be another reason the residents would have given. Got a warning to check my rears about 10 mins outside of the final meet spot.
Its a charity cruise, and they start defecting. Oh there will be a letter in the paper about this one!
Every single old bat that I drove past through the hills just looked and stared in shock and horror as I drove by in my totally stock standard quiet car... had a good lol everytime, received honks and mid fingers from oncoming traffic aswell.
Stopped dead in the middle of the road at this one straight section because a pair of emus decided to walk slowly across, I stopped and honked and one of them turned and poked its head forward as if it was about to run at me to attack ;)
reckless driving as in burnouts/ loud take offs ?
Or the other reckless driving as in doing a fart , driving over 2300rpms, starting up your car, etc etc ? grandma spec reckless driving >?
anyone witness it ?
i can vouch, douchebags stopping to rip skids up the corkscrew, had a rexy all over both lanes in front of me for half the cruise. that s15 with the vault chromies lunched it, straight into a guard rail.
parked at the bp at the finish meet point, got word of cops from scandy and heslo so left from there. then sorta ended up next to heslo, a dark blue 33 and a lighter blue 33 cruising back towards ttp way, all sticker free i think.
you know why
because ive heard in a number of media reports lately the words "hoon" and "car enthusiast" get merged into one group statement
so we're now "hoon car enthusiasts"
thanks media mike, ya f**khead
did u escape sticker free?
My car got looked over and got cleared, bastard stopped me as I was tryin to leave, he went all through inside car, glove box ,centre console . Are they alowed to go through inside of car, or they need a warrent?
125 reports from hills residence!!
Im not suprised, one of the S13 drift cars i was behind for a bit was drifting like he was at lala. Also spotted an old dude filming people going up corkscrew with his camera, then just after corkscrew everyone decided to pull over for a burnout show, few cars infront of me stop and i almost rear ended them and then i had cars doing skids right next to my car in the oncoming lane while i was stuck behind people ;)
Well as with most cruise, there were the boro spec and track spec cars. The cop i was talking to was more annoyed that the organiser was no where to be found. I know Wayne and his mate had some guy actually block the road with his car in Montacute just after the Corkscrew! Now there is reckless endangerment!
If they have suspecion Nick they can
Reckless driving, excessive noise, driving without due care, you name it
I think that the cops are full of shit. The cruise would have been lucky to pass 125 people and the chance of every one of them picking up the phone and calling the cops is very unlikely. they would have received 20 calls max if they received any.
Remember the cops were notified of the cruise because it was an official cruise and they would have decided long ago that they were going to "have a strong presence", so regardless of what happened people were going to get defected.
Edited by D_Stirls
But Old Mark cant be everywhere at once, although we tried to keep the guy there..he did start getting quite pedantic "wheres the organiser of this cruise?" "can you guess why we are here?"
Kinda makes you second guess wether you come out to these cruises anymore. After doing nothing wrong, you still get a giant target painted to your car.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
