  • Replies 14.2k
theyre at tyrepower mate. theyre open tomorrow, and i can just call them up and say "such and such is gonna collect 1 of my front wheels today" if you need to grab one.
random note
few weeks back went to a job down in kensington gardens, to put a service on a pole. me and my senior spent 5 mins trying to find this pole "out front of #4 eden avenue"
then after a closer look we found this
had to go back there this week, wouldnt even recognise it
edit, helps if i put the right one up hey
Edited by Matty 31
random note
just wondering if you were or you know the linee from st marys that got caught riding in the bucket back to the depot when his hard hat fell off and hit the cop car traveling behind the truck. I laughed when i heard that one
Edited by ducati02
Damn all those lucky people that get holidays from work, i only get Xmas day (25th), Boxing Day (26th), Boxing Day Holiday (28th), and New Years day (1st 2010) off, i am working all the rest :D...well at least i get some money.
WELL, today after work i thought id put my carbon fibre heat sheild on, What a head F**k. Any ways finally got it in place and everything connected back up(well i thought i did). took it for a drive gave it a bit of boost and 'BANG', bunny hopped to side of road and lost power, popped the hood and intercooler pipe going into turbo had come off, totally forgot to clamp in back together. Could i get it back on? geeeeez did i struggle, lucky i had a flat blade to leaver it on all good now :D
ah, workin till the 24th but then off till the 18th jan :)
had our xmas show today, mental note: jetty bar make very average parmys
Nearly the same as me, I got from the 23rd till the 18th.
23rd is our Summernats
:D
yeah wayne just read it then , sorry had a trillion messages today..
not really in need of a tow car now, as my mate just bought a stag, and purposely looked
for one with a tow bar just to tow my car...
you will get 750 for it easy like ya said, whack it in trader
LOL @ all cunce whingeing about only getting a few days off over the Chrissy period, least you actually get days off in the first place. I work in a servo, open every day of the year. I get 0 days off over the Chrissy break.
Gotta get up @ 4:30am to open the shop on the morning of my birthday too (26th) :)
Needless to say, any days I have no night shift and no morning shift the next day, I will be absolutely shitfaced :D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
