  • Replies 14.2k
Hey Craig, do you still have any spare turbo's to suit RB20? I think my ceffy needs a new one, it makes one hell of a bad scream on anymore than 10psi :banana:
Will a RB25 turbo fit? I have the one off my car...not sure if i will need to keep it in-case i get defected.
they sure do and a RB25 one is better as the RB20 can run more boost through it before the ceramic wheel shatters
Na sorry Chad, they both sold...
but do what the others said, 25 turbs on a 20 is a good upgrade.
hey that reminds me, i gotta come pick up that fuel pump, unless you will be needing it for the ceffy now?
I'll probably just use the RB20 turbo that i have in my shed for now then go for something with a steel wheel later on.
I'll try have a look and see what sort of pump is in the ceffy 2moro and if its only got a stocker then i'll probably need to chuck in the 040.
How much do you want for it, i need a standard RB25 turbo to get the 25>180sx conversion engineered. It one of the last parts i need.
Chad i ended up with that TD06-17c but it's too laggy for a RB20. You wouldn't be seeing full boost until 4500+ RPM but it will support up to 275kw.
Edited by D_Stirls
I dont exactly want to sell it as i MAY need it to clear a defect if i get done, and i don't want to go hunting for one. As i am not using it, i am willing to lend for awhile.
Any idea what kind of power the Cef is making Chad?
Eh, bought myself a weekend project. Silly thing is that this car is getting done quicker than my driven car. Had a base idea of an all white 32 gtr, with some white rims, which i love.
Ended up looking like this as of 20 minutes ago.
Just wanted to get a general opinion from you guys.
So I've been driving manual for well over a year now. I have been told different stories on what gear to use while cruising down the road at 60 (or 66 :) ) km/h. I've generally gone to fifth gear as I've heard that it saves petrol, but I've heard other stories telling me that it's not so good for the engine. What's the general concensus out there?
Was walking down hindley around 3am this morning. I see the undercovers 4wd, cops jump out to help with this fight. One guy who was involved in the fight runs off towards me and 5 cops chase after him down hindley. My mate kicks the guy in the leg, slows him down abit, cops still chasing him, tackle him from behind and the guy goes straight to the ground. Everyone cheers.
Was fun to watch this guy get decked.
Thats my exciting night :)
Why? I have an 040 ready to go in.
oh npz :geek::)
So I've been driving manual for well over a year now. I have been told different stories on what gear to use while cruising down the road at 60 (or 66 :bunny: ) km/h. I've generally gone to fifth gear as I've heard that it saves petrol, but I've heard other stories telling me that it's not so good for the engine. What's the general concensus out there?
so long as the engine is not laboring it shouldn't do damage but as for saving you fuel that's an urban myth. i used to do the same but don't any more
if you're not labouring it, use 5th
ive gone back to that in my fourby, gets me an extra 100km out of a tank easy just doing that
oh npz :bunny::)
Not quite sure how you came to that conclusion, 5th gear at 60 is using fewer revs then 4th gear at 60 hance lower revs = less fuel used
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
