  • Replies 14.2k
Hey Craig, do you still have any spare turbo's to suit RB20? I think my ceffy needs a new one, it makes one hell of a bad scream on anymore than 10psi :banana:
Will a RB25 turbo fit? I have the one off my car...not sure if i will need to keep it in-case i get defected.
they sure do and a RB25 one is better as the RB20 can run more boost through it before the ceramic wheel shatters
Na sorry Chad, they both sold...
but do what the others said, 25 turbs on a 20 is a good upgrade.
hey that reminds me, i gotta come pick up that fuel pump, unless you will be needing it for the ceffy now?
I'll probably just use the RB20 turbo that i have in my shed for now then go for something with a steel wheel later on.
I'll try have a look and see what sort of pump is in the ceffy 2moro and if its only got a stocker then i'll probably need to chuck in the 040.
How much do you want for it, i need a standard RB25 turbo to get the 25>180sx conversion engineered. It one of the last parts i need.
Chad i ended up with that TD06-17c but it's too laggy for a RB20. You wouldn't be seeing full boost until 4500+ RPM but it will support up to 275kw.
Edited by D_Stirls
I dont exactly want to sell it as i MAY need it to clear a defect if i get done, and i don't want to go hunting for one. As i am not using it, i am willing to lend for awhile.
Any idea what kind of power the Cef is making Chad?
Eh, bought myself a weekend project. Silly thing is that this car is getting done quicker than my driven car. Had a base idea of an all white 32 gtr, with some white rims, which i love.
Ended up looking like this as of 20 minutes ago.
Just wanted to get a general opinion from you guys.
So I've been driving manual for well over a year now. I have been told different stories on what gear to use while cruising down the road at 60 (or 66 :) ) km/h. I've generally gone to fifth gear as I've heard that it saves petrol, but I've heard other stories telling me that it's not so good for the engine. What's the general concensus out there?
Was walking down hindley around 3am this morning. I see the undercovers 4wd, cops jump out to help with this fight. One guy who was involved in the fight runs off towards me and 5 cops chase after him down hindley. My mate kicks the guy in the leg, slows him down abit, cops still chasing him, tackle him from behind and the guy goes straight to the ground. Everyone cheers.
Was fun to watch this guy get decked.
Thats my exciting night :)
Why? I have an 040 ready to go in.
oh npz :geek::)
So I've been driving manual for well over a year now. I have been told different stories on what gear to use while cruising down the road at 60 (or 66 :bunny: ) km/h. I've generally gone to fifth gear as I've heard that it saves petrol, but I've heard other stories telling me that it's not so good for the engine. What's the general concensus out there?
so long as the engine is not laboring it shouldn't do damage but as for saving you fuel that's an urban myth. i used to do the same but don't any more
if you're not labouring it, use 5th
ive gone back to that in my fourby, gets me an extra 100km out of a tank easy just doing that
oh npz :bunny::)
Not quite sure how you came to that conclusion, 5th gear at 60 is using fewer revs then 4th gear at 60 hance lower revs = less fuel used
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
