  • Replies 14.2k
if you're not labouring it, use 5th
ive gone back to that in my fourby, gets me an extra 100km out of a tank easy just doing that
+1. I'm almost always in 5th at 60 km/h and and when it's flat I often go through 50 Km/h zones in 5th too. :)
if i try to use 5th at 60kmh, the car nearly stalls....
1st = 0-96km/h
2nd = 133km/h
3rd = 175km/h
4th = 205km/h
5th = 2xxkm/h
Factors Affecting Fuel Economy
Fuel economy is affected by a vehicle's size, weight, aerodynamics, fuel delivery system, engine type and transmission type. These values remain constant for a specific vehicle.
There also are many variable factors. As mentioned, the heating value of the petrol is one. In addition, fuel economy is affected by weather conditions, air conditioner use, road conditions, the route driven, driving speed and driving style. And it is affected by the mechanical condition of the car - engine tune, wheel alignment and tyre pressure. Some of these non-petrol factors have the potential to cause substantial changes in fuel economy. The table below shows a list of average and maximum effects published by the United States Environmental Protection Agency (EPA).
Click for image
Winter-related factors can combine to lower fuel economy 20% compared to the summer. Rain or snow on the road offers more resistance to the tires. It may also require the driver to slow for safety to a less fuel-efficient speed. In cold weather, a richer air-fuel mixture is required to start and warmup the engine. And much of the warmup is done at idle because of the need to defog or defrost the windows. Also, in many vehicles, the air conditioner is operated to assist defogging. More energy is required to overcome the resistance created by the higher viscosities of cold lubricants - engine oil, transmission fluid, and differential lubricant.
Short trips are worse for fuel economy than long trips because a cold engine uses more fuel than a warm engine and because of the energy required to overcome the resistance of cold lubricants. Traffic jams and bumper-to-bumper driving also extract a heavy toll on fuel economy.
http://www.chevron.com/
Conclusion
We don’t think any of the points made in this article are groundbreaking. Bluntly, they are not. But if you select the car carefully on the basis of the real needs it must satisfy, keep it well maintained and drive it well, you will be getting the best fuel economy possible in your driving circumstances.
No shit! :)
that article doesn't mention the use of 5th gear at 60-65 km/h....
uhm... fuel consumption isnt directly effected by revs, load has more of effect.
Revs has something to do it for sure, the lease cars i used to get with the trip meters in them that show instant fuel usage backs that up, driving down heaslip road doing 90 it'd be showing me using more fuel in 4th at higher revs then 5th in lower revs...But Steve has also hit the nail on the head with that post he's put up sums it all up really
Was walking down hindley around 3am this morning. I see the undercovers 4wd, cops jump out to help with this fight. One guy who was involved in the fight runs off towards me and 5 cops chase after him down hindley. My mate kicks the guy in the leg, slows him down abit, cops still chasing him, tackle him from behind and the guy goes straight to the ground. Everyone cheers.
Was fun to watch this guy get decked.
Thats my exciting night :(
LAWL i saw that i was crossing the road all the cops ran out the 4wd n ran past me n ma mate haha i thought someone cleaned the guy up be4 the cops did becoz everyone was clapping n cheering hahaha oh god it was funny!!
epic fail for the guy fleeing the scene :)
lol, not a bad score at all. considering you can buy the same seat in the same condish for about 10 times that.
shame that rail i pulled off it is a passenger rail. might just flog it.
+1, my old man told me that 5th should be reserved for anything over 80, and that goes for the majority of cars
you need a certain amount of revs to cycle the oil system to the required pressure, I would never drive 60kph in 5th unless it was downhill (in which case the drivetrain is not under load)... the gear ratios in a GTR are quite nice imho, I wouldnt want to change the ratios for a daily driven car... on my weekend hills run, i very rarely used 5th gear and the fastest we went was 115kph, so I kept it in 4th for most of the way, and the entire 2 hour run took just a tad over a quarter tank... most of the time the car was in 3rd doing 4000rpm around corners, so I wasn't being gentle, and yet it took much less fuel than I estimated
-D
woo got my seat from JMS, little bit haggered but nothing i cant fix up. not bad for $49 :)
if you change your mind and your wanting to off load it ill give you 100bux for it how it is.
im keen to use it in a ps3, steering wheel setup lol
if not ill just keen using the ebay jobby but fixed back in your living room sucks wang
yeah RB20 isn't too fond of doing 50k in 5th, will just handle 60 aslong as there isnt any hills or sudden accelleration required, but 4th fits the bill fine, even 80 in 4th sits fine. Will be interestering to compare the new 25/25 engine/gearbox combo...
lol. this is where i up the bid to $150... could use a passenger seat. :)
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
