lol, id rather hang out with friends, nice dinner and drive, than spend $150 in a room filled with sweaty guys and girls listening to only some music im interested in.
doubt you will get a lot of sweat happening in apple bar somehow Damo...too nicely dressed to break a sweat really....its just a different environment....
  • Replies 14.2k
ugh. got the clutch back from acs today.
im looking at about $1100 to get it ready to use. lol.
thought it was a metallic or a ceramic clutch, in which case a rebuild is up to maybe $500.
but nope. its a carbon single plate.
hah, doubt you could get a basically new ats/across/carbonetics/acs single plate carbon for anything less than $1500 though, so in that respect, its alright value.
Edited by scandyflick
haha I'm keen!
Luciano? Priess? Weezy? J-Dawg?
I'm still waiting for Damo to come out and hit town with everyone :)
And yeah, I had a feeling it wouldn't be real popular simply due to the amount of locals, hint of hardstylez, etc. Nik Fish is more suited to L!ve and Earth venues... def not HQ. And yeah, throw in a international DJ and it'd be packed.
Im in for sure. Perhaps even a early mix before heading in :)
lol, spot on mate - its not a packed club full of off tappers sweating their nuts off jumping up and down with hands in the air; i'm pretty confident to say it'd be a lot classier, casual, sit down have a drink and actually hear yourself talk over the tunes (but still at a nice volume on a big system), a lot of females on the dancefloor, with room to move
you're onto something Craig mate!
Keen as. I've got a few mates who are/were resident DJ's at Savvys, Marble, etc and would be keen to also join us. They're into more prog, house stuff.
very nice!
i'll be keen for sure, just depending on when - i'm hopeless with plans especially this time of year
a lady at my work got stabbed in the face and her purse stollen!
some fat flamin mongrel charged her, stole her purse and slashed her face.
then one of the forkies drove his fork into the middle of the street trying to block the road off abit but drove up the curb and nearly hit one of the bosses mates new lexus.
found out later that the dude stole a cops gun, the car he was driving in and then when the cops where getting a report from some of us he tried robbing the NAB down the road got nothing went on to another and nothing.
rammed a few cop cars along the way too. this dude must have been high as a kite!
work locked us inside. could here cop car and choppers etc. (still got made to work though, lol)
hopefully everyone elses day wasnt so eventfull!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
