  • Replies 14.2k
Nice power James! That will keep you busy. What turbos are you running again?
PS - A smaller file would have sufficed.
Running HKS 2530's not sure on them exactly
Very nice! :yes:
Thanks Vu ;)
is that all?
weak.
176 rings a bell Dave ;)
hahahaha @ file size 2.7mb its not a stroked RB by any chance RB27mb :P /silly
what boost controler do you have very nice figure for 18psi
excellent AFR too
Thanks Steve, yeah was in a hurry so just scanned it and uploaded it :(
Running a HKS EVC off the Ark, good 8yrs old. Haha yeah found out its actually closer to a 2.7ltr unlike i was told when i bought it. But yeah Simon did a great job considering the conditions. Another tune in the new year once i've got a few things sorted (boost controller, exhaust) and see what i get :rofl:
176 rings a bell Dave :(
171 thankyou very much.
noteworthy differences,
im down 0.7l, 2 cylinders, 1 turbo, and a forged hks rebuild scratch that, but add a full house top end.
im sure if i had similarly built engine... say a 2.2l tomei genesis with a suitable turbo, we'd be pretty well matched. ;)
Edited by scandyflick
Well results from today are pretty good, besides their a/c being down and room temp at 43 and a cactus boost controller. Im pretty happy :(
wow, that is some nice power James!!
what internals do you have?
Std carnk and rods, 50thou over N1 pistons, serious head work, 2530's, 750cc injectors, ah i'll add the link its easier
http://www.skylinesaustralia.com/forums/60...html&hl=GTR
ahh nice!
gotta be happy with that!!
i'm making the same power with an unopened motor :)
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
