  • Replies 14.2k
Nice power James! That will keep you busy. What turbos are you running again?
PS - A smaller file would have sufficed.
Running HKS 2530's not sure on them exactly
Very nice! :yes:
Thanks Vu ;)
is that all?
weak.
176 rings a bell Dave ;)
hahahaha @ file size 2.7mb its not a stroked RB by any chance RB27mb :P /silly
what boost controler do you have very nice figure for 18psi
excellent AFR too
Thanks Steve, yeah was in a hurry so just scanned it and uploaded it :(
Running a HKS EVC off the Ark, good 8yrs old. Haha yeah found out its actually closer to a 2.7ltr unlike i was told when i bought it. But yeah Simon did a great job considering the conditions. Another tune in the new year once i've got a few things sorted (boost controller, exhaust) and see what i get :rofl:
176 rings a bell Dave :(
171 thankyou very much.
noteworthy differences,
im down 0.7l, 2 cylinders, 1 turbo, and a forged hks rebuild scratch that, but add a full house top end.
im sure if i had similarly built engine... say a 2.2l tomei genesis with a suitable turbo, we'd be pretty well matched. ;)
Edited by scandyflick
Well results from today are pretty good, besides their a/c being down and room temp at 43 and a cactus boost controller. Im pretty happy :(
wow, that is some nice power James!!
what internals do you have?
Std carnk and rods, 50thou over N1 pistons, serious head work, 2530's, 750cc injectors, ah i'll add the link its easier
http://www.skylinesaustralia.com/forums/60...html&hl=GTR
ahh nice!
gotta be happy with that!!
i'm making the same power with an unopened motor :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
