  • Replies 14.2k
got more details on the head work please???
No idea really, besides whats in the link
ahh nice!
gotta be happy with that!!
i'm making the same power with an unopened motor :rant:
Yeah considering the temp in their dyno room yesterday its pretty good. cooler day and with their a/c fixed, and a boost controller that'll hold more pressure, should be able to get atleast another 20-40kw out of it :(
woot woot new clutch has arrived.....cannot wait to slap it in and not worry about 3rd gear slippage :D
also very very nice power figure there James.....cant wait to see what mine will be making once all is fixed and retuned.....close to 270rwkw hopefully :)
Chad,
Jan 16th
coming?
I'll try and make it for sure, i've finished work for the year now so i'll get stuck into the car. Few problems i have are, turbo is nearly dead, diff spins one wheel at times, handbrake does nothing at high speeds. suspension is nismo struts with cut springs :D If i can get a few of those things fixed i'll be there.
Who's fitting it Krishy :)
Hmmm, I need help putting in my new clutch, with a freshly machined flywheel, redline gearbox oil, castrol transfer case oil, rear main, spigot bush, and C's short throw shifter? Know anyone Luke lol!? :D
Std carnk and rods, 50thou over N1 pistons, serious head work, 2530's, 750cc injectors, ah i'll add the link its easier
http://www.skylinesaustralia.com/forums/60...html&hl=GTR
Nice pick up there James, lots of serious mods too, must of saved a packet in the long run, be good to her!!!
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
