  • Replies 14.2k
got more details on the head work please???
No idea really, besides whats in the link
ahh nice!
gotta be happy with that!!
i'm making the same power with an unopened motor :rant:
Yeah considering the temp in their dyno room yesterday its pretty good. cooler day and with their a/c fixed, and a boost controller that'll hold more pressure, should be able to get atleast another 20-40kw out of it :(
woot woot new clutch has arrived.....cannot wait to slap it in and not worry about 3rd gear slippage :D
also very very nice power figure there James.....cant wait to see what mine will be making once all is fixed and retuned.....close to 270rwkw hopefully :)
Chad,
Jan 16th
coming?
I'll try and make it for sure, i've finished work for the year now so i'll get stuck into the car. Few problems i have are, turbo is nearly dead, diff spins one wheel at times, handbrake does nothing at high speeds. suspension is nismo struts with cut springs :D If i can get a few of those things fixed i'll be there.
Who's fitting it Krishy :)
Hmmm, I need help putting in my new clutch, with a freshly machined flywheel, redline gearbox oil, castrol transfer case oil, rear main, spigot bush, and C's short throw shifter? Know anyone Luke lol!? :D
Std carnk and rods, 50thou over N1 pistons, serious head work, 2530's, 750cc injectors, ah i'll add the link its easier
http://www.skylinesaustralia.com/forums/60...html&hl=GTR
Nice pick up there James, lots of serious mods too, must of saved a packet in the long run, be good to her!!!
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
