  • Replies 14.2k
This happened twice tonight, I'm going 55 in a 60 zone (to conserve fuel) and in both cases, a cop in front of me slows down to around 40, even when he has other cars behind him. Once he realised that my car is completely stock they turn off into some random side street, probably pissed off that he won't meet his quota tonight :wub:
i think you will find the police drive slow everywhere, unless there is a reason to be somewhere.
Thing is though, he was probably going 55-60 as well before he spotted me, and as soon as I slowed down to around 45, he slowed to around 40.
Meh, you want practical... buy a Hyundai Excel lol
cmon theres a difference between practical and pussy
like people running low low suspensions that cant even handle twisties because "oh it makes my wheels rub on the guards"
maybe think of running your car half a bees dick higher and it'll be able to >do what the car was designed to do<
autosalon spec suspension = fail. twisties + cruise/daily spec suspension = win. especially in south australia, where roads are designed by orks.
-D
-1
Impractical as buggery. Fine on jap roads but here you'll be rubbing more than oprah's thighs in a marathon
looks like turd to boot.
-D
Edit: +1 for Dohmars' second post.
discovered 3 things in the last 48hrs
1. Vics are very courteous drivers on their highways / freeways (ie if you're coming off an entry ramp, they change lanes so u can get in)
2. Amber lights dont stay amber long at all (barely a second)..........so no more "plenty of green in that" calls over there
3. i need an intercooler on the patrol BADLY
win, wonder if its static or bagged. extra points of its static dropped.
as for the practicality thing... meh, im running pretty low with a reasonably aggressive (*waits for jarrad*) wheel and tyre combo, and the only place ive ever had trouble with rubbing on the guards (im not counting liners, theyre retarded) has been turn 1 at mallala, over 100km/h and tipping into a long right without brakes puts a lot of weight into the front left corner, solution, bought it into the sheds, hammered the tabs on the guards down, went back out and it wasnt as much of a problem. skinnier tyre would fix it completely.
... could use some rca's though, then itd be spot on.
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
