  • Replies 14.2k
This happened twice tonight, I'm going 55 in a 60 zone (to conserve fuel) and in both cases, a cop in front of me slows down to around 40, even when he has other cars behind him. Once he realised that my car is completely stock they turn off into some random side street, probably pissed off that he won't meet his quota tonight :wub:
i think you will find the police drive slow everywhere, unless there is a reason to be somewhere.
Thing is though, he was probably going 55-60 as well before he spotted me, and as soon as I slowed down to around 45, he slowed to around 40.
Meh, you want practical... buy a Hyundai Excel lol
cmon theres a difference between practical and pussy
like people running low low suspensions that cant even handle twisties because "oh it makes my wheels rub on the guards"
maybe think of running your car half a bees dick higher and it'll be able to >do what the car was designed to do<
autosalon spec suspension = fail. twisties + cruise/daily spec suspension = win. especially in south australia, where roads are designed by orks.
-D
-1
Impractical as buggery. Fine on jap roads but here you'll be rubbing more than oprah's thighs in a marathon
looks like turd to boot.
-D
Edit: +1 for Dohmars' second post.
discovered 3 things in the last 48hrs
1. Vics are very courteous drivers on their highways / freeways (ie if you're coming off an entry ramp, they change lanes so u can get in)
2. Amber lights dont stay amber long at all (barely a second)..........so no more "plenty of green in that" calls over there
3. i need an intercooler on the patrol BADLY
win, wonder if its static or bagged. extra points of its static dropped.
as for the practicality thing... meh, im running pretty low with a reasonably aggressive (*waits for jarrad*) wheel and tyre combo, and the only place ive ever had trouble with rubbing on the guards (im not counting liners, theyre retarded) has been turn 1 at mallala, over 100km/h and tipping into a long right without brakes puts a lot of weight into the front left corner, solution, bought it into the sheds, hammered the tabs on the guards down, went back out and it wasnt as much of a problem. skinnier tyre would fix it completely.
... could use some rca's though, then itd be spot on.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
