  • Replies 14.2k
its 10 to 7, and im slightly wasted. as norman can attest. i told him to invade poland. :banana:
:edit: f**king hell, i cant even spell slightly. i fixed it so you dontt notice though... oh f**k, im telling you about it... balls.
Edited by scandyflick
ive lost track of the beers ive drank. and i can still touch type. f**k you all! and kate miller heidke is playing on someones ipod.
im drinking with a lesbian and some random chick.
