  • Replies 14.2k
if anyone see's LEX around can you tell him to give me the $192.50 he owes me from the track day! as he doesnt seem to wanna listen to me when i ask for it.. always excuses..
is there anything i can do to get it??
cops?
cops?
Make a page on facebook and get all his facebook friends to join it :blink:
And when you do see him, make sure he doesnt walk up to your car while its idling and hit limiter in neutral like he did to mine.
Who the gosh darn is this cvnt?
And Adrian. I'd offer him a baseball bat across the head.
cops?
Yeah that's pretty piss poor. It's been how long now?
3 months? tried to meet a vilis nothing.. said deposit to my bank nothing.. now wont reply..
f**k that's really average
I just posted something on his wall on facebook, feel free to comment :blink:
Haha, I lol'ed
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
