D_Stirls Posted January 5, 2010 Share Posted January 5, 2010 I don't think that the turbo is dead chad. If it was dead it would be showing Vac all the time and wouldn't get to 0 as it's actually producing boost to get to 0. Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5018254 Share on other sites More sharing options...
SLED Posted January 5, 2010 Share Posted January 5, 2010 I've had a cooler pipe come off before and i could only drive at walking speed. I drove the car home like normal, it rev'd to 4000rpm no prob, just takes ages to get there. It was blowing some smoke higher in the revs so I'll have a good look at it 2moro and see if anything has come off. can still be a leaking hose Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5018311 Share on other sites More sharing options...
Blue32 Posted January 5, 2010 Share Posted January 5, 2010 Hey Jenkies how are u mate?Just letting u know if u dont already, but my engine was getting stuck on the front diff shaft, what u need to do is open the front diff housing, in the middle there a 4 splines which rotate around, u need to put a lever bar in there and a slight tap will pop the shaft out. This got me stuck for a good 3hrs. Hey Luke (and Jenkies) You don't need to remove the front diff housing - with a couple of lever bars / big flat head screwdrivers you can pop the shaft out in no time at all........saying that well done for succeeding anyway!! Never give up I say! Cheers, Andrew Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5018334 Share on other sites More sharing options...
DSTROY Posted January 5, 2010 Share Posted January 5, 2010 I don't think that the turbo is dead chad. If it was dead it would be showing Vac all the time and wouldn't get to 0 as it's actually producing boost to get to 0. can still be a leaking hose Took it for a drive just before and it was blowing white smoke like a train. Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5018400 Share on other sites More sharing options...
Carbon 34 Posted January 6, 2010 Share Posted January 6, 2010 Took it for a drive just before and it was blowing white smoke like a train. sounds like the turbo in my VR4, it blew a on the Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5018501 Share on other sites More sharing options...
Krishy Posted January 6, 2010 Share Posted January 6, 2010 Took it for a drive just before and it was blowing white smoke like a train. yep that sounds like its completely f@#ked Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5018569 Share on other sites More sharing options...
dark.sky Posted January 6, 2010 Share Posted January 6, 2010 RB20's are tough little luggers, mine has between 80 and 92PSI on ALL 6, and it has oil in the water, but it still pulled quite a decent figure a couple of weeks ago.. and it blows smoke too.. and I found out my RB25 is still probably a month away the place in Japan (not Streeter, the original seller) forgot to tell anyone that thier forklift broke Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5018585 Share on other sites More sharing options...
Krishy Posted January 6, 2010 Share Posted January 6, 2010 Damn that 20 has taken a punishment Dion....good to hear that its still going mate...have fun when the 25 goes in there Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5018612 Share on other sites More sharing options...
TALBO Posted January 6, 2010 Share Posted January 6, 2010 Not sure if anyone gives a ...., but Hussey and Siddle are doing an unfknbelievable job at the moment! Go Aussies Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5018633 Share on other sites More sharing options...
Inline 6 Posted January 6, 2010 Share Posted January 6, 2010 who? Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5018656 Share on other sites More sharing options...
Damo_R34 Posted January 6, 2010 Share Posted January 6, 2010 Not sure if anyone gives a ...., but Hussey and Siddle are doing an unfknbelievable job at the moment! Go Aussies i do, loving every second, we might actually pull off a win Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5018665 Share on other sites More sharing options...
Krishy Posted January 6, 2010 Share Posted January 6, 2010 i do, loving every second, we might actually pull off a win Aussie's will most likely loose this test match and damn right they should....a poor first innings performance by them see Pakistan in a easy position to take a win...currently 3/65 and only needing 176, which i think that they will comfortable get.... will make an exciting third test Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5018923 Share on other sites More sharing options...
Carbon 34 Posted January 6, 2010 Share Posted January 6, 2010 Cricket is farking Boring,, and I hold them responsible for all the hot weather too..hahahaha Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5019020 Share on other sites More sharing options...
Carbon 34 Posted January 6, 2010 Share Posted January 6, 2010 damn double post Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5019021 Share on other sites More sharing options...
craig R33 Posted January 6, 2010 Share Posted January 6, 2010 (edited) for Chad RB25 series 2 turbo, Inspector done by JIS and havent put in the car yet. Fit straight into RB20DET engine. -$375Sms only please, 0433353768 (I not get on here often now so sms is the best idea) SSR SP1 17x9, 17x9.5. Cant remember with the offset, I think the front is +19 and the rear +11. Front tyres had about 70% and rear has about 60%. Its on my cefiro and look tuff. -$2000 neg Edited January 6, 2010 by craig R33 Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5019039 Share on other sites More sharing options...
Krishy Posted January 6, 2010 Share Posted January 6, 2010 bahahah nice find troy Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5019040 Share on other sites More sharing options...
DSTROY Posted January 6, 2010 Share Posted January 6, 2010 (edited) for Chad Way ahead of ya mate, going to pick up that turbo tonight Not that keen to pay $2000 on a set of rims for a drift hack. Also does anyone have an RB20 that i can have a look at so i can work out where the water lines on the turbo go to? or take some pics? My current turbs has no water lines so i need to find out where to hook some up. Edited January 6, 2010 by DSTROY Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5019070 Share on other sites More sharing options...
craig R33 Posted January 6, 2010 Share Posted January 6, 2010 they all in shape Chad, all you have to do is line them up, its near impossible to get mixed up lol Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5019084 Share on other sites More sharing options...
RubyRS4 Posted January 6, 2010 Share Posted January 6, 2010 they all in shape Chad, all you have to do is line them up, its near impossible to get mixed up lol Unless he's going braided lines Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5019096 Share on other sites More sharing options...
DSTROY Posted January 6, 2010 Share Posted January 6, 2010 (edited) they all in shape Chad, all you have to do is line them up, its near impossible to get mixed up lol Thing is i dont have any water lines. I'll have to buy some rb25 ones instead. I have noticed that on the block there in a hard line coming off of the block and one coming from behind the engine and they are joined with rubber hose. im thinking these are the old lines cut and joined? maybe i can cut the new lines and just join them to the old ones. Edited January 6, 2010 by DSTROY Link to comment https://www.sau.com.au/forums/topic/291831-the-sa-wasteland/page/228/#findComment-5019099 Share on other sites More sharing options...
