  • Replies 14.2k
called tech support, they made me discconnect my phones which got me to 2.3mbps
my vodafone shit just hit 5.10mbps!
blah! GAY
Do you have a home alarm system, or cable TV...how many phones you got connected to your phone line?
As these can interfere with the ADSL. Every phone needs a filter, and then you can only use 3 filters, after which you need a central filter splitter. If you have a monitored home alarm system or cable TV you are going to need to ring them and organize to have a filter installed. I would also suggest getting rid of the Belkin ASAP, billion FTW, get a Billion 5200G ~$129, or better yet a 7300GRA ~$139, prices off the top of my head.
This should be in the computer thread for future reference I suppose but I've got the Netgear DG834N....how do they fair in relation to Billion & Belkin Abe?
i also happen to use a netgear router (cant remember the model number) and so far its done me good....
Dave won't receive a summons for "speed dangerous" (even though it's warranted for 45kph over).
The $600 fine, 6 demerit points & 6 mths loss of licence is actually a very good outcome for the cops.
I advised Dave to return the cops phone call immediately (to make their life easier) without any admission which is what they want from you when they ring.
For them to serve him a "speed dangerous" now, it would tie up the courts and further govt expense for possibly not necesarily a better outcome than they have on the table now. There have been lawyers that have argued the "proof of driver" deal before and although the "speed dangerous" is then dropped, they still result in loss of licence & fines.
If Dave on the other hand said, "yeah that was me driving", he'd expect another visit me thinks.........whenever you are 45kph over, you'll always get a phone call or visit 1st for that very reason.
I am JUST about to go onto my P2's... and I think I might be getting in trouble again. Gotta goto court... FFS S13. Got impounded on 1/1/10 lol. Heaps awesome kick off to 2010 :(.
The cops were actually pretty good and he said I shouldn't have anything to worry about in court but we will see how I go :\ I'm never getting off my f**ken P's lol
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
