  • Replies 14.2k
is there kits you can buy to replace all the hose's on a rb26. i thought i seen em somewhere but i can only see heater hose kits around.
i had a tiny leak in the radiator bypass hose but was thinking i might just replace them all for piece of mind.
apparently that 1 bit of hose costs $70.
Edited by Inline 6
Hey i went there and watched.. and it was hot as balls. I thought about putting my car down the strip but it was way too hot for it. so i just watched all action from the stands. there were a lot of nice cars out there.
thanks for coming and saying hi then :banana:
ok pop quiz, who can tell me what this hose is called or what it does exactly.
starts on left side of motor here, did lil angle. top of the pic you can see where it starts to say rb26 if you not sure where it is :P the hose im talking bout comes off near the large top radiator hose and heads to the right side of the motor
in which its hard to see exactly what its doing under nearth my turbo piping here. its the lower of the 2 skinny hoses here
just started leaking coolent on me, fortunately i only drove for about 2k when it happened and its a tiny pin hole so coolent was still full.
sale of wheels saga, entry number 46734:
found another dude whos keen, some random apprentice that owns a hr31 coupe, shall be collecting a deposit soon. rad.
any suggestions for new wheels?
viennas, hanging 12 miles out the guards
overfender the f**k outta it
then see if ya can get stickered before ya lose ya licence lol
*edit*
ive got nothing lol
Edited by Matty 31
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
