  • Replies 14.2k
ive checked all 16 pages of the diy thread..... how do i remove all the hicas pumps in engine bay correctly and how do i remove the abs?? anyone now of a step by step information page?
Jenkies u will need a non abs brake master cylinder and possibly some new lines made.
And Jake I'm not a mechanic I just know some car info lol
aww man thanks... nothing is ever perfectly easy is it :)
see my gtr for an example :) i dont regret not having abs, it hardly ever locks and when it does its pretty easy to ease off and get it gripping.
mine is the opposite.. i find it pritty easy to lock all 4s up with ABS, but that might have something to do with tyres XD
you bloody legend! ive never ever had the abs actually work on me which means my pedal control must be decent.. need the space to mount a catch can so i can leave battery in bonnet! thanks again chad
Anyone know how to replace wheel bearings? or a link to how to do it...
you'll need a press as they are pressed into the hubs, And if they are anything like the S-Series they are like $90 each for the bearings.
He can just split the front and rear lines and then put a biasing valve on the rear line. regency will be happier with a factory non abs setup though. although he'll have bigger problems if regency ever look at the car.
Edited by D_Stirls
what tyres you got? i got cheapish tyres (nankangs) but mine are 275s all round so that probably helps me a fair bit.
and also post-31501-1263854503_thumb.jpg 4466
Edited by Inline 6
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
