  • Replies 14.2k
Depends what you want i guess, Internally gated or External.
GT3071R Dual BB rated at 500hp, $1,815
GT3071R T25/T28 Internally gated with a .64 rear housing, $1,795
GT3071R T25/T28 internally gated with a .86 rear housing is also the same price as the one above.
Courtesy of Tweakit.com.au
its pretty expensive build to do tho.. some1 told me on ns.com to have 20g ready to do the 3071R turbz on my pulsar(plus the supporting engine/diff upgrade) he also told me my straight cut gears wouldnt be able to handle 300awkillerwasps, is there many things stronger than ppg straight cut gears?... bit of a turn off right there...
Jeremy i reckon he doesn't know what he's talking about 20k is rather large and gtir are already turbo
only thing is 3071r on a 2.0lt might be a bit laggy
ring AM Performance he makes dumps and might know a lot more about the gtir that some rando on NS
oh and i know 3071r isnt rated for 300kw i just asked about that seperately.. if it was 15k id do the pulsar, 20k is pushing it... got to get rid of the stupid s13 :)
How much for the sil?
lol that turbo will do all of that.....should be quite responsive with a small 0.64 rear housing.....mine is a 0.62 or a 0.63 rear housing and see full boost by 3200-3400rpm.....
http://www.lovecricket.com.au/
so far my highest score is 105
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
