  • Replies 14.2k
cos my foctory ones had hacks everywhere and i got em really cheap.. whats wrong man?!?! diddnt mean to offend ya :O
They just look ricey, more suited to a stripped out race car.
Edited by DSTROY
i know this, but when doing a 20 conversion, why not run atleast a side mount?
I'm going to say, because none of the standard piping etc would line up or at all be usable with a VL engine bay.
Too much hole cutting and chopping out airbox trays etc.
Be alot more effort then its worth, and why bother cutting a whole heap of holes in the bay when you will eventually upgrade to a FMIC. The crossover pipe is a great bandaid fix just to get the car moving imo so long as the car ran standard boost with std timing etc.
Maybe I am putting too much thought into this :\
stripped out race car!?!? u mean this?! hahahaha
lol! that reminds me, you keen on coming up to this http://www.loveday4x4adventures.com/Australian4x4Muster.html I might head up with my sister. I just want to win the Landcruiser that was painted up at my bro in laws paint shop :O
Looks like i better keep inspiring u Jenkies :O
On friday night my mate and i got stuck into fixing my battery tray from where battery acid had spilt before i brought the car.
First off was the cut the stupid thing out.
Then weld in a sheet of alloy.
Then add some primer.
Then seam sealer
Then use some tripple 2 s (think that whats its called) makes the paint stick like crazy.
Then on came the paint. :P
post-38653-1264324901_thumb.jpg post-38653-1264324955_thumb.jpg post-38653-1264324999_thumb.jpg post-38653-1264325081_thumb.jpg post-38653-1264325145_thumb.jpg
And thats how it is now :)
its ok, i have a 5 year warranty on stains and rips :rant:
you may want to give the warranty a close read mate.
i dont think ranga jizz is covered, something about it being biologically phucked up or some shit
and cant be removed with they cleaners they have....
just a story i heard.
too much thought :) easy as! i got a few lengths of stainless from paramount browns some second hand factory intercooler pipes from various workshops for free cut a few holes made a few brackets and hey presto! :) still vl's are in the past :rant:
lol! that reminds me, you keen on coming up to this http://www.loveday4x4adventures.com/Australian4x4Muster.html I might head up with my sister. I just want to win the Landcruiser that was painted up at my bro in laws paint shop :D
will have to see if i can get the time off but that would be awesome!!!
Looks like i better keep inspiring u Jenkies :P
Then seam sealer
Then on came the paint. :)
LUKE THATS INTENSE MATE!!! its more epic than karnivools new albumn :P
just a story... it sounds like an argument that you had when trying to return your lounge room curtains
hey hey. long time no speak. how is everyone??
i'm great, Amber is 10 months old today. she has kept me VERY busy, crawling around trying to get into all sorts. she's started walking along furniture hehe.
well i'll hopefully be on here more often :rant:
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
