  • Replies 14.2k
What would it mean if a car was spitting and splitting and losing power.
On idle, it's dropping revs and almost stalling.
I checked the leads and they looked ok, but I don't gave a tool to get my plugs out it seemed to have gone walk abouts.
Checked and tighten everything I could. It's a charade btw
Can that....looks like it survived the ordeal.
I suppose you could give it a razor and it could put itself out :P
It even took the pics of your car Cara!! :)
bahahahahahahaha thats well put Pete! nice one!
but the EMU lol had to be killed, i thought it was already dead but it must have just been knocked out, my mate Dale, who lives in Renmark came to my rescue, and he unfortunatley had to kill it, i didnt see it move, but he said it nealry caused a 5 car pile up because it was trying to get on the road and a L plater slammed on the brakes and 4 cars behind him and swerve to miss him....
but on a serious note she will be picked up by my crash repairer tomorow, i was able to get in contact with him yesterday........id hate to know what a new front guard is gonna cost from nissan, i already know the headlight will cost $1800.......
if there are a fair few scratches on my door window does anyone know if they will replace that too?
Scartchs just mean they will sand back and repaint, dents that cannot be removed will mean it is to be replaced
________
I just love it when I organise someone to come pick the silvia up, spent the better part of this whole week negotiating prices etc, and then I'm told he will be coming last night, changes it to today and Midday, and now his phone is off.......
Its a shame because he looks to be a pretty active SAU user, not just some no name person that seen my FS thread..
FFS!!
Edited by Weezy
running your gt3076 with the .7 compressor housing on your low mount manifold might have clearance problems with your engine mount
when i mounted my gt35 on my 6boost low mount manifold i had to have the engine mount machined down a bit to make it clear
Adrian as i said above^^^^^
I WARNED YOU THAT IT WILL HAVE CLEARANCE PROBLEMS!!!!!!!!!!!
I just left a thing on your FB but I'll post here,
Ummm, every now and then my car will drop idle and bounce round for a few seconds and then idle and drive fine, then other times i'll be cruising at whatever speed/RPM and it'll do the same similar thing just drop like all power etc for a few seconds and then act and drive fine.
In my old VLCT, I experianced the same thing with my RB30ET... Could be AFM's too :\
Hmmm... odd problem indeed. If I were you I'd borrow someone else's CAS to try it out first, no point buying one only to find that wasn't the problem to begin with. Besides Nissan will charge you through the ass for one me thinks. I can get you a price if you really want
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
