  • Replies 14.2k
What would it mean if a car was spitting and splitting and losing power.
On idle, it's dropping revs and almost stalling.
I checked the leads and they looked ok, but I don't gave a tool to get my plugs out it seemed to have gone walk abouts.
Checked and tighten everything I could. It's a charade btw
Can that....looks like it survived the ordeal.
I suppose you could give it a razor and it could put itself out :P
It even took the pics of your car Cara!! :)
bahahahahahahaha thats well put Pete! nice one!
but the EMU lol had to be killed, i thought it was already dead but it must have just been knocked out, my mate Dale, who lives in Renmark came to my rescue, and he unfortunatley had to kill it, i didnt see it move, but he said it nealry caused a 5 car pile up because it was trying to get on the road and a L plater slammed on the brakes and 4 cars behind him and swerve to miss him....
but on a serious note she will be picked up by my crash repairer tomorow, i was able to get in contact with him yesterday........id hate to know what a new front guard is gonna cost from nissan, i already know the headlight will cost $1800.......
if there are a fair few scratches on my door window does anyone know if they will replace that too?
Scartchs just mean they will sand back and repaint, dents that cannot be removed will mean it is to be replaced
________
I just love it when I organise someone to come pick the silvia up, spent the better part of this whole week negotiating prices etc, and then I'm told he will be coming last night, changes it to today and Midday, and now his phone is off.......
Its a shame because he looks to be a pretty active SAU user, not just some no name person that seen my FS thread..
FFS!!
Edited by Weezy
running your gt3076 with the .7 compressor housing on your low mount manifold might have clearance problems with your engine mount
when i mounted my gt35 on my 6boost low mount manifold i had to have the engine mount machined down a bit to make it clear
Adrian as i said above^^^^^
I WARNED YOU THAT IT WILL HAVE CLEARANCE PROBLEMS!!!!!!!!!!!
I just left a thing on your FB but I'll post here,
Ummm, every now and then my car will drop idle and bounce round for a few seconds and then idle and drive fine, then other times i'll be cruising at whatever speed/RPM and it'll do the same similar thing just drop like all power etc for a few seconds and then act and drive fine.
In my old VLCT, I experianced the same thing with my RB30ET... Could be AFM's too :\
Hmmm... odd problem indeed. If I were you I'd borrow someone else's CAS to try it out first, no point buying one only to find that wasn't the problem to begin with. Besides Nissan will charge you through the ass for one me thinks. I can get you a price if you really want
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
