  • Replies 14.2k
na, id keep the ca, manual it, blow it (bound to happen) then 20 conversion...
i just dont have that kinda cash upfront :banana: missus on maternity leave still, mortgage, wedding, 31 build bill...
list goes on.. might sell the 31 when its finished, depends how it goes
if i had the upfront cash, id have that 13 my friend
I'd recommend getting an R32 ECU and chucking nistune on there, and chuck that in the 33... would be very inexpensive ($200 for the daughterboard, $40 for fitting + the cost of a 2nd hand 32 ecu)...only thing u might have to do is change the o2 sensor depending on what ur 33 already has... ive had my nistune for 24 hrs and im loving it more than a fat kid loves cake
-D
so my car blew an ecu ,
awesome
should i just save up for a remap ?
or buy another stockie ecu haha
-D
yeah thats what im thinking of doing
would be amazing
i just dont have that kinda cash upfront :) missus on maternity leave still, mortgage, wedding, 31 build bill...
Swaps for the 31 :)
FKN LOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOL
on a slightly much more srs note, i want an s13 now... and the 31 hasnt even been finished haha
*cough* V-Rod *cough*
-D
you would be better off with a VG30 ECU there rather then the RB20 ECU.....VCT controls yo....
