  • Replies 14.2k
One of the scary things is whenever I visit the Facebook page of a random chick, be 18, 26 or whatever years of age, they always seem to have Dan as a mutual friend. Oh, and happy birthday to you as well.
happy birthday to you as well Angerman!
i wont deny it, im banging half of adelaide. i think its the result of adding people that ive talked to like once, i dont know half those people :cool:
Also note normsta is stalking randoms on facebook :)
adelaide aint exactly that big though.
Edited by Inline 6
well, i think my finger is broken. Sucks how you have to go to the doctor, they get paid just to tell you that you need an xray! I could have established that myself, wheres my gap?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
