  • Replies 14.2k
Ive got a r32 wing to get rid of. 30bux in silver
Rubes - got the actuator ready for you. need to test the larger 18pound unit a bit later
will get it to you next week then.
ordered my 235/45 khumo ku36 tyres
also qfm a1rm 780degree track pads
sorted out front and rear braces, awaiting a seat rail for my seat.
also awaiting 4l surge tank & 305lph external fuel pump. comes with 5m braided fuel line
a cheap chip remap is on its way to me so I'll be piggybacking around the tune until I sort my shite out
trying to sort out the injectors, then will be ready to service and do all fluids.
in will go the roll cage to some extent, do a tune and she'll be ready.
sore-as atm, lol
$15 remap chip, lol
9000rpm, speed cut, boost cut, mapping
lol go ebay, like the $1.25 certified roll cage, $100 yellowjacket coilpacks, etc,
with my mapecu piggyback she should be good.
if not, meh. thought Id try tho.
wiring is all done, was lots and lots of spaghettio's of nothingness
found 2 on/off switches, about 10m of wires connected to nothing
everything is out tho, ready for the cage to go in.
No worries mate. I'm flying out to Sydney on Wednesday, not back until Sunday evening. No rush! :)
Then I got the actuator to fit, new intercooler piping to fit, A custom centre console to finish, and a turbo/boost leak to sort out all in one hit! :)
$15 remap chip, lol
does this mean your not going to buy my power fc??? =\
Does anyone here know of anyone or a place that i looking for night time workers?
Or even anytime after 4pm?
I'm doing full time studies now to get things moving quicker so I can finally be qualified!
Thanks yo!
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
