  • Replies 14.2k
quite possibly :stupid:
nice
sell off all you dont need, grab 2ndhand what you do need, and go for it
my 6700 r32 sedan rb26 has been reduced by around 1200 in parts sales
then added 3500 back into it to get it up to track-standard.
then less 5500 for bike sale. fun project
today i installed the braided front brake lines, front slotted rotors, and qfm a1rm track pads all round
hoping tomorrow my ju-36's arrive
here is the list from my car:
1993 Nissan Skyline GTs-T Rwd 4door grey sedan4 - $6700
RB30 5speed manual rebuilt gearbox with single button clutch
GTR RB26DETT engine with new rebuilt turbos
5Zigen 3" turbo back exhaust
Turbotech manual boost controller - $35
GTR intank fuel pump
Walbro 305LPH external fuel pump - $165
4 litre alloy fuel surge tank with 5m braided fuel lines - $265
550cc Siemens Injectors with new O-rings & seals - $350
Iridium spark plugs 0.75mm gap - $50
Yellow Jacket coil packs - $150
600x400x100mm fmic kit
Drift pod air filters
Oil filter relocation kit - $110
Oil cooler finned cylinder kit - $90
Ryco oil & fuel filter
Castrol Edge 6L oil
Fujimoto oil drain valve - $35
BHP roll cage - $5
Tomei 300kph GTS dash
AEM wideband kit - $250
Autometre boost gauge
Saas gear knob - $30
Saas steering wheel & boss kit - $170
Bride seat rail - $165
Gephardo race seat & 5-point harness - $200
Nismo ecu remap - $30
Map-ECU piggyback to stock ecu - $200
Car alarm - $35
Hood scoops - $25
GTR rear wing - $25
Tein suspension
Greddy strut tower brace & strut boot brace - $100
Nismo front tension rod link set
Slotted front disc rotors
Braided front brake lines - $80
QFM A1RM 780degree track brake pads - $235
17inch RJR Grafic mags
235/45/17 Khumo KU36 semi-slick tyres - $750
anything not listed means it was already on the car
i'll work it out and send u a pm mate
Awesome, gives me time to save up for a clutch etc.
Speaking of Clutches, i have made a choice of 3;
Xtreme Heavy Duty Clutch Kit $800
NPC 10" Heavy Duty Copper Mix Organic Kit $1093.50
ORC 409D-01N Kit $1399
What do people here suggest, or think?
NPC that will rate about 350 rwkw and its a great clutch
should be ceramic though ?? or did you ask for organic
also 10" is a pull type clutch do you have a pull type
I asked for a 95% street, 5% track type of clutch, and i drive an R33 GTST, so my guess is pull type. They say the clutch is good for 300rwkw and retains the factory feel.
i would get a ceramic Abe and just because its a R33 i wouldnt guess its pull most RB25 boxes are push but the GTR's have pull
your's being 1997 might be pull so don't know see if you can get it down to boostworx or another reputable workshop and get them to check it out
ive heard a lot of people praise and bag Jim Berry
they prolly say 300kw because its ceramic when i did the group buys the ceramic push clutches were 350kw and i sold them into 2x R33's this is why i say better check if its push or pull
push is a bit cheaper there push type Ceramic cushioned with 1200kg pressure plate rated for 350kw used to be about $656 << going from memory 2 years ago
see a lot of info in >>This Thread<<
note all links that say click are dead due to there website being upgraded
Abe - Jim Berry: Race Cluth, leave yourself a good hour and give him a call =) worth if for the info alone
Does he have email? I prefer to have things written down so i can reread and refer back to it.
a while ago they invented these things called pens and paper... some people find them useful, apparently jim is one of these people =P
just my hot tip, dont go for a soild centre cluth!!! :P
f**k luke, you can be a smart arsed flamin mongrel sometimes hey?
dont know if its just me, or my general tolerance being a bit lower of late, but that didnt seem to be a necessary comment to make. same as the mystery that you were trying to elude to in the domestic vs import dyno day thread.
grow up man, seriously
/rant
/rant
wtf is your problem?
english too dificult for you to understand??
i told him that jim doesnt use e-mail? how is that unnecessary??
and the mystery in the dyno day thread was a broken dyno!!! i don't exactally want to say "bosstworx dyno is broken, so dont go there"
think the only person here that needs to grow up is you!
/rant
Its not just you!
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
